Archicad C++ API
How tro freeze a layer
I would like to have a sample code on how to freeze a layer.
4 REPLIES 4
TomWaltz
There is no "freeze" layer command in Archicad... can you be a little more specific about what you want to do?
Tom Waltz
Well, I meant like locking the layers kind of what can be done in AutoCAD.
I meant if I want to lock a layer by running a script. That means through coding. Not through interface.
cheers,
Srinivas.
Akos Somorjai
You'll have to use ACAPI_Attribute_Modify to change the locked status of a layer.
HTH,
Akos
