2020-07-06
09:40 AM
- last edited on
2021-09-15
11:47 AM
by
Noemi Balogh
GSErrCode __ACENV_CALL CommandHandler (const API_MenuParams * /*params*/) { GSErrCode err; char errMsg [50]; API_Element element; API_ElementMemo memo; API_LibPart libPart; API_GetPointType pointInfo; double aParam; double bParam; Int32 addParNum; // Load a object BNZeroMemory (&libPart, sizeof (libPart)); strcpy (libPart.ownUnID, "{CE0BB097-2FE3-4399-B6DA-80681BD99C60}-{00000000-0000-0000-0000-000000000000}"); err = ACAPI_LibPart_Search (&libPart, false); if (libPart.location != NULL) delete libPart.location; err = ACAPI_LibPart_Get (&libPart); if (err != NoError) { sprintf (errMsg, "ACAPI_LibPart_Get: %d", err); ACAPI_WriteReport (errMsg, true); return err; } // Click a point BNZeroMemory (&pointInfo, sizeof (API_GetPointType)); CHTruncate ("Click a point", pointInfo.prompt, sizeof (pointInfo.prompt)); pointInfo.changeFilter = false; pointInfo.changePlane = false; err = ACAPI_Interface (APIIo_GetPointID, &pointInfo, NULL); if (err != NoError) { sprintf (errMsg, "ACAPI_Interface: %d", err); ACAPI_WriteReport (errMsg, true); return err; } // Placing a object BNZeroMemory (&element, sizeof (API_Element)); BNZeroMemory (&memo, sizeof (API_ElementMemo)); element.header.typeID = API_ObjectID; element.header.guid = GSGuid2APIGuid (GS::Guid ("{CE0BB097-2FE3-4399-B6DA-80681BD99C60}")); err = ACAPI_Element_GetDefaults (&element, &memo); if (err != NoError) { sprintf (errMsg, "ACAPI_Element_GetDefaults: %d", err); ACAPI_WriteReport (errMsg, true); return err; } err = ACAPI_LibPart_GetParams (libPart.index, &aParam, &bParam, &addParNum, &memo.params); if (err != NoError) { sprintf (errMsg, "ACAPI_LibPart_GetParams: %d", err); ACAPI_WriteReport (errMsg, true); return err; } //element.object.head.guid = element.header.guid; element.object.libInd = libPart.index; element.object.pos.x = 0; // pointInfo.pos.x; element.object.pos.y = 0; // pointInfo.pos.y; element.object.level = 0; // pointInfo.pos.z; element.object.xRatio = aParam; element.object.yRatio = bParam; err = ACAPI_Element_Create (&element, &memo); if (err != NoError) { sprintf (errMsg, "ACAPI_Element_Create: %d", err); ACAPI_WriteReport (errMsg, true); return err; } ACAPI_DisposeElemMemoHdls (&memo); return NoError; } // CommandHandler ()
GSErrCode __ACENV_CALL CommandHandler (const API_MenuParams * /*params*/) { const char hwText[] = { "This multistyle\nword was created\nby the Element Test example project." }; API_Element element; API_ElementMemo memo; GSErrCode err = NoError; BNZeroMemory (&element, sizeof(API_Element)); BNZeroMemory (&memo, sizeof(API_ElementMemo)); element.header.typeID = API_TextID; ACAPI_Element_GetDefaults (&element, &memo); element.text.charCode = CC_UTF8; element.text.loc.x = element.text.loc.y = 2; element.text.anchor = APIAnc_LB; element.text.multiStyle = true; element.text.nonBreaking = false; element.text.useEolPos = true; element.text.width = 150; element.text.charCode = CC_Default; memo.textContent = BMhAll (Strlen32 (hwText) + 1); if (memo.textContent == NULL) return APIERR_MEMFULL; strcpy (*memo.textContent, hwText); // create the text element err = ACAPI_Element_Create (&element, &memo); // clean up ACAPI_DisposeElemMemoHdls (&memo); return err; } // CommandHandler ()
Solved! Go to Solution.
2020-07-06 12:18 PM
2020-07-06 12:18 PM
2020-07-06 02:03 PM
Ralph wrote:Thank you, Ralph.
Every database change has to be enclosed in an undoable session. Are you calling this function within that context? If not, take a look atACAPI_CallUndoableCommand.
2020-07-06 02:20 PM
GSErrCode __ACENV_CALL CommandHandler (const API_MenuParams * /*params*/) { GSErrCode err; char errMsg [50]; API_Element element; API_ElementMemo memo; API_LibPart libPart; API_GetPointType pointInfo; double aParam; double bParam; Int32 addParNum; // Load a object BNZeroMemory (&libPart, sizeof (libPart)); strcpy (libPart.ownUnID, "{CE0BB097-2FE3-4399-B6DA-80681BD99C60}-{00000000-0000-0000-0000-000000000000}"); err = ACAPI_LibPart_Search (&libPart, false); if (libPart.location != NULL) delete libPart.location; err = ACAPI_LibPart_Get (&libPart); if (err != NoError) { sprintf (errMsg, "ACAPI_LibPart_Get: %d", err); ACAPI_WriteReport (errMsg, true); return err; } // Click a point BNZeroMemory (&pointInfo, sizeof (API_GetPointType)); CHTruncate ("Click a point", pointInfo.prompt, sizeof (pointInfo.prompt)); pointInfo.changeFilter = false; pointInfo.changePlane = false; err = ACAPI_Interface (APIIo_GetPointID, &pointInfo, NULL); if (err != NoError) { sprintf (errMsg, "ACAPI_Interface: %d", err); ACAPI_WriteReport (errMsg, true); return err; } // Placing a object BNZeroMemory (&element, sizeof (API_Element)); BNZeroMemory (&memo, sizeof (API_ElementMemo)); element.header.typeID = API_ObjectID; element.header.guid = GSGuid2APIGuid (GS::Guid ("{CE0BB097-2FE3-4399-B6DA-80681BD99C60}")); err = ACAPI_Element_GetDefaults (&element, &memo); if (err != NoError) { sprintf (errMsg, "ACAPI_Element_GetDefaults: %d", err); ACAPI_WriteReport (errMsg, true); return err; } err = ACAPI_LibPart_GetParams (libPart.index, &aParam, &bParam, &addParNum, &memo.params); if (err != NoError) { sprintf (errMsg, "ACAPI_LibPart_GetParams: %d", err); ACAPI_WriteReport (errMsg, true); return err; } //element.object.head.guid = element.header.guid; element.object.libInd = libPart.index; element.object.pos.x = 0; // pointInfo.pos.x; element.object.pos.y = 0; // pointInfo.pos.y; element.object.level = 0; // pointInfo.pos.z; element.object.xRatio = aParam; element.object.yRatio = bParam; err = ACAPI_CallUndoableCommand ("Create text", [&] () -> GSErrCode { return ACAPI_Element_Create (&element, &memo); }); if (err != NoError) { sprintf (errMsg, "ACAPI_Element_Create: %d", err); ACAPI_WriteReport (errMsg, true); return err; } ACAPI_DisposeElemMemoHdls (&memo); return NoError; }
