Archicad C++ API
IAPIToolUIData::SetUserData
Oleg
May be anybody knows details about following.
For the reference:
TestSettingsPageObserver::SetUserDataToDefault function in Panels.cpp of the Panel_Test example.
userData.dataHdl handle is not released ( BMKillHandle ) after call of SetUserData.
Is it a bug ( and memory leak ) in this example or the handle really is not required to be released in this case ?
Andras Babos
Graphisoft Alumni
Graphisoft Alumni
You're right Oleg, that's a bug.
The last lines of that method should look like this:
	tabPage->uiData->SetUserData (&userData);
	BMKillHandle (&userData.dataHdl);
It will be corrected in the next DevKit.
Andras.
Oleg
Thank you Andras. You have confirmed my guesses. Actually I used BMKillHandle in my code, but asked as I had some doubts.
