IES light files
Is there a way to get the location of a source IES light file? When reading the ParameterList data of the lights in a BaseElement, the actual file name is listed in the C4D_PHO_FILE field but no source path.
I'd like to either get the path to the original file or the imported content.
I'm creating the IES light by using the ArchiCAD library part "IES Light 18.gsm" and setting the Photometric File Name field to the IES file I'm importing. (I need the IES info for an external renderer.)
Any tips appreciated.
UPDATE: actually getting the info from the light instance is far preferable to a source path (for portability).
2 Replies 2
To continue the conversation with myself, I can locate the library item that represents the IES file and was hoping to retrieve the custom data via ACAPI_LibPart_GetSection. But I'm not sure what kind of data ID I need to pass in. I've tried most of the standard ones (the 4-char codes) but I may be doing something else wrong.
When I export the light and convert to XML it doesn't look like the IES info is there.
Well, in that case I merge the two topics to ease this conversation.
Sorry, I cannot answer your questions I am not a C++ programmer.
