Archicad C++ API
IO::File::ReadBin and CopyBin returns FileNotFound error
ReignBough
I created a function that supposed to read a binary file.
I was able to open (IO::File::Open) the file without error but when I read (IO::File::ReadBin) the file, it returns 0x81000100 (FileNotFound) and the "destination" is empty. When I copy (IO::File::CopyBin) it, it also returns the same error but the content was copied. EDIT: Copied to "destination".
Why it return this error?
~ReignBough~
ARCHICAD 26 INT (from AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
Ralph Wessel
Mentor
I've used this function in my code without problems. Could you post some code to show what you're doing?
Ralph Wessel BArch
Active Thread Ltd
ReignBough
//err = IO::fileSystem.GetSpecialLocation(IO::FileSystem::ApplicationFolder, &apxPath); // not APX location
LPSTR apxPath = new TCHAR[_MAX_PATH];
GetModuleFileName((HINSTANCE)&__ImageBase, apxPath, _MAX_PATH);
char* pos = str_lastchr(apxPath, '\\');
pos[1] = 0; // get only the location
IO::Location binPath;
binPath.Set(apxPath);
IO::Name fname = IO::Name(/*input: filename without extension*/);
fname.Append(".bin"); // file extension
err = binPath.AppendToLocal(fname);
//binPath.PrintDebug();
// open file
IO::File srcFile(binPath);
err = srcFile.Open(IO::File::ReadMode); <== no error here
// get size
USize szStr = 0;
err = srcFile.GetDataLength(&szStr); <== no error here, returns correct file size
++szStr;
// read file
char* srcStr = new char[szStr]();
//err = srcFile.ReadBin(srcStr, szStr); <== returns 0x81000100 (FileNotFound), srcStr is empty
err = srcFile.CopyBin(srcStr, szStr); <== returns 0x81000100 (FileNotFound), srcStr contains what I needed
~ReignBough~
