2019-07-18 10:46 PM - last edited on 2022-10-05 01:24 PM by Daniel Kassai
GS::Array<API_Guid> elemList; err = ACAPI_Element_GetElemList(API_WallID, &elemList, APIFilt_OnActFloor); //get all elements of a type id on active floor API_Neig** selNeigs = (API_Neig * *)BMAllocateHandle(sizeof(API_Neig) * elemList.GetSize(), ALLOCATE_CLEAR, 0); int selCount = 0;//Added counter to keep track of exact number of elements afterwards. for (GS::Array<API_Guid>::ConstIterator it = elemList.Enumerate(); it != nullptr; ++it) { //This is how the Archicad api documentation says to iterate all elements of a type API_Element element; BNZeroMemory(&element, sizeof(element)); element.header.guid = *it; //element.header.typeID = API_WallID; if (ACAPI_Element_Get(&element) == NoError) { float rad2deg = 57.2958f; ACAPI_WriteReport("wall angle is: %f", false, element.wall.angle * rad2deg); ACAPI_WriteReport("wall info: %f", false, element.wall.height); if (element.wall.angle == 0) { continue; //skip correct walls } (*selNeigs)[selCount].guid = element.header.guid; ++selCount; } } selNeigs = (API_Neig * *)BMReallocHandle((GSHandle)selNeigs, selCount * sizeof(API_Neig), 0, 0); err = ACAPI_Element_Select(selNeigs, selCount, true); BMKillHandle(reinterpret_cast<GSHandle*> (&selNeigs));In the code above I'm just iterating all walls and using that collection to add walls to the current selection.
2019-07-19 02:40 PM
