concepsys
Wall accessories documentation or manual?
Hello,
Where can I find any documentation regarding programming gdl objects based on the Accessories add-on for Archicad?
21 Replies 21
Hmooslechner
There are none. You just can open one of the existing GDLs for the additional library for the admins and look for yourself through the code. Is basically taking some of the element-parameters and makes holes and edge-forms  with Group-Objects and SEO-substracts it from any additional form to get the result.
concepsys
Thank you for your reply.
That is what I am starting to do now but I had to ask.
Even some basic instructions would take me less lot of time than having to go through discovering the idea behind these objects.
I have some very robust accessories I've built, pm me and maybe we can chat and I can give some guidance.
concepsys
Hello SenecaDesignLLC
By reading the default object code, as suggested by Hmooslechner, I believe I have grasped the concept for now.
It seems simple enough. I will do some testing.
I don't want to bother you without doing my homework first.
If I come across something that I don't understand, I'l contact you.
Thank you so much.
Feel free to ask me questions I have built wall roof and slab accessories that I use on the daily for framing siding soffit fascia floor systems and they all output quantities.
I've learned a lot of the basic tricks of you want a head start on your homework.
Good luck!
gaba
I am also interested in this topic and I have a key question: is it possible to place more than one (or two) wall equipment object on the wall? Because from my tests it seems that only two objects: outer and inner. And is there a way to get around this?
"When you seek knowledge, you will eventually find it. Then you will become its source - until such time as you must seek it again."
AC 7 - 29, Twinmotion | Windows 10 Pro for Workstations
Dell 7740 Xeon | 128GB | Quadro RTX 5000 16GB + LG 2560x1080
I just applied 3 of the same wall accessory (different settings) to the same side of the wall.
gaba
@Barry and if you move the wall, will the 3 accessories still be linked to the wall? Because in my case, unfortunately, only the last accessory moves with the wall and the previous ones lose their connection to the wall. And it makes no sense to put on many accessories. Because I add a window and not all accessories update.
This is true.
Only one inside and one outside accessory remains linked.
So, yes there is a limit to one per side.
