go
concepsys
since ‎2009-08-13
‎2026-08-24
User Statistics
  • 35 Posts
  • 1 Solutions
  • 35 Likes given
  • 41 Likes received
User activity
When opening rendering settings or starting render directly, Archicad would wait for about 5 minutes and then opened a message saying "Cineware by maxon add-on has unexpectedly closed". Even in a new empty file. This was happening both in Archicad 26 & 29, the version I have...
Hello, I have spent a few hours trying to understand why is that an object will show the fill that I defined in Master script on plan view on Archicad 26 and Archicad 27 but not in Archicad 28. I have searched for new features in Archicad 28 GDL, tried different type of proj...
Hello, This message is intended to help who ever needs to convert library parts to a previous version and for my own future reference. I searched this forum to find an easy solution to make my AC26 library compatible with AC25. My library has several files, including folders...
I am struggling with a problem that I find only on the Wall accessory add-on (not the ROOF or the SLAB):I get the wall points from ac_bot_poly and ac_top_poly.I try to create an array that returns the contour line defined by these points.I decompose this array into two simpl...
Hi,We have recently been informed by our local reseller of the licensing transition program that will change the current web based or physical licenses into a new cloud based subscription system.We are Archicad users but also Archicad library developers. We have developed li...
