Le Tan Kien
Layer Combination API
I want to create an add-on that switches to the view named "9:平面画像作成用". Is there a way to do this? Please guide me.
5 Replies 5
AllanP
GSErrCode ACAPI_Navigator_ChangeCurrLayerComb ( API_AttributeIndex * layerCombIndex )
https://graphisoft.github.io/archicad-api-devkit/group___navigator.html#gab55c4569a18237a48fce470793...
I have been using ArchiCAD continually since ArchiCAD 4.5
Member of Architalk since 2003, but missed the migration from Architalk to Graphisoft Communities. Melbourne, Australia
Le Tan Kien
Can you give me an example snippet to switch to that layer? I’ve tried it but it doesn’t switch to the layer. Thank you sir.
AllanP
API_AttributrIndex layerCombInd = 21;   // the layer combination id of the desired layer
GSErrCode    err = NoError;
in Archicad 25 it was
err = ACAPI_Environment(APIEnv_changeCurrLayerCombID, &layerCombInd);
now in Archicad 28 i think it is
err =ACAPI_Navigator_ChangeCurrLayerComb ( &layerCombInd );
Le Tan Kien
Thank you sir, but not work @@
Le Tan Kien
Thank you sir, I am done
