‎2014-02-19
10:44 AM
‎2023-08-01
04:35 PM
Doreena Deng
subset.customNumbering = true; subset.useUpperPrefix = false; subset.addOwnPrefix = false; subset.numberingStyle = API_NS_noID;Then, I created a layout with API_DatabaseInfo->ref set to "Cust002".
db_info.typeID = APIWind_LayoutID; swprintf(db_info.ref, L"Cust002"); swprintf(db_info.name, L"Test Layout"); db_info.masterLayoutUnId = iMasterLayout; err = ACAPI_Database(APIDb_NewDatabaseID, &db_info, &parent);But when the layout was created, the ID is empty. Also in Layout Settings dialog, 'Use Automatic Book and Subset ID assignment' is checked and 'Custom ID' is unchecked.
‎2014-02-25 03:58 AM
API_NavigatorItem new_item;
BNZeroMemory(&new_item, sizeof(API_NavigatorItem));
new_item.mapId = mItemData.mapId;
API_Guid guid = item.guid;
mErr = ACAPI_Environment(APIEnv_GetNavigatorItemID, &guid, &new_item); errln = __LINE__;
if (mErr != NoError) { /* error handle */ }
API_DatabaseUnId db_unid = item.db.databaseUnId;
API_LayoutInfo layout_info;
mErr = ACAPI_Environment(APIEnv_GetLayoutSetsID, &layout_info, &db_unid);
layout_info.customLayoutNumbering = true;
sprintf(layout_info.customLayoutNumber, iUiid);
mErr = ACAPI_Environment(APIEnv_ChangeLayoutSetsID, &layout_info, &db_unid); errln = __LINE__;
This will modify the uiid of the layout.
