Martin Walter
Loading DLL from AddOn fails for ArchiCAD27
I have working code for an ArchiCAD-Addon for Versions 22-26. Now I try to run it with ArchiCAD 27 but it fails in the following line:
m_hModule = ::LoadLibrary(wstrDLLPath);
LoadLibrary() returns 0.
I investigated, that ::GetLastError(); returns 127, that means a Procedure is not found.
This does not make much sense in the ::LoadLibrary function.
Maybe it is the
BOOL APIENTRY DllMain(HMODULE hModule, DWORD  ul_reason_for_call, LPVOID lpReserved);
function that is missing in my DLL. Or did I miss something else?
AC22-27, Windows 11, i7-1355U, 32GB RAM, 2TB SSD
1 Solution
Martin Walter
I found my mistake: It is my own DLL and it includes some ArchiCAD API functions. I compiled and linked it against the ArchiCAD 26 API and tried to load the DLL with ArchiCAD 27.
Go to post
2 Replies 2
Akos Somorjai
Hi Martin,
Couple of questions:
Is this your own DLL?
Is it on a path accessible by Archicad?
Can you load it if you place the DLL beside Archicad 27?
Best, Akos
Martin Walter
