Aathil
LNK 2019 Unresolved external symbol
I have a function to get the library part index from name.
The function uses GS::DefineConstatntUTF16CharacterOrString() method.
On building this function is not resolved. And is giving the following error:
ArchiCADElements.obj : error LNK2019: unresolved external symbol "__declspec(dllimport) unsigned short const * __cdecl GS::DefineConstantUTF16CharacterOrString(char const * &)" (__imp_?DefineConstantUTF16CharacterOrString@GS@@YAPEBGAEAPEBD@Z) referenced in function "int __cdecl GetLibraryIndex(char const *,enum API_LibTypeID)" (?GetLibraryIndex@@YAHPEBDW4API_LibTypeID@@@Z)
The function is defined in uchar_t.h . Correct me if I am wrong, the corresponding dependency library is :
\Support\Modules\GSRoot\Win\GSRootImp.LIB which is already included in the project's additional libraries.
How to fix this issue?
#include "uchar_t.hpp"
#include "ACAPinc.h"
#include "APIEnvir.h"
#include "ArchiCADElements.hpp"
Int32 GetLibraryIndex(const char* name, API_LibTypeID typeId)
GSErrCode err;
API_LibPart searchPart;
auto str = GS::DefineConstantUTF16CharacterOrString(name);
GS::ucscpy(searchPart.docu_UName, str);
err = ACAPI_LibPart_Search(&searchPart, false);
if (searchPart.location != nullptr)
delete searchPart.location;
if (err == NoError)
return searchPart.index;
std::cout << "Could not find library part with name:" << name << std::endl;
return 0;
Thanks
1 Solution
kolioi
If you open uchar_t.hpp header file, you can see that you're not allowed to use the function DefineConstantUTF16CharacterOrString() alone. That function is called from the macro L(str) which takes as a parameter string or character constants only. You can not call the function with a variable because it doesn't have implementation.
In your case, you have to convert multibyte string to wide-character string. There are several ways to do that but maybe the easiest way is to use GS::UniString. Something like this
GS::ucscpy(searchPart.docu_UName, GS::UniString(name).ToCStr().Get());
Go to post
kolioi
