dushyant
Location of AddOn SourceCode for compilation
Hi
Where do you keep the source-code of the addon to be compiled? Does it have to be in the 'Examples' folder of the API Kit?
Thanks
10 Replies 10
dushyant
Ok. Thanks for sharing that.
I now have set up the variable only for the root of the devkit and changed all the references in to the libraries in the template like:
$(AC_DEVKIT)/Support/Modules/...
This variable can be changed using a userMacro in a custom property sheet. So now only one variable to control. I don't have to target various versions of the devkit at the moment, so this setup works for me
