2016-12-21
05:40 AM
2023-07-12
08:56 PM
Doreena Deng
2016-12-23 10:04 PM
poco2013 wrote:Hi,
I'm trying to create a basic add-on on the MAC using the supplied template. It shows up fine in the initial creation menu but after the project is created, it is brought in without setting a target. According to the instructions, the template should be put into the "application plug-in" folder under the xcode paths. Which needed to be created per instructions. However, nothing shows up in the targets when i try to assign the target. Tried using the bundle target but it is not recognized by Archicad.
What setting should i use. Don't what to strip out everything from one of the examples such as the Geometry test. Looking for a easier solution.
Using Archicad 20 and the December release of the API. XCODE 8.2
2017-01-17 01:28 PM
poco2013 wrote:Hi,
2017-04-08 09:47 AM
2017-04-18 10:09 AM
2017-04-18 12:25 PM
2017-04-18 12:45 PM
2017-04-18 01:09 PM
