Archicad C++ API
Modeless dialogs
Oleg
The API doc states:
"API-based Add-Ons CANNOT handle modeless dialog boxes. Use Palettes
instead."
It is a pity, I need a modeless dialog, not a palette. Though I tried to
open modeless dialog box, as far as I remember, I had problems and it
seems this dialogs really impossible to use.
May be anybody knows any safe workaround to use it ?
5 REPLIES 5
Ralph Wessel
Mentor
Oleg wrote:
The API doc states:
instead."
I use modeless dialogs for 'About' windows. It works well, but they don't do much either. It can be a bit confusing from a user's point of view because window commands like 'Close' don't apply to it, and close the window behind instead.
What kind of effect are you trying to achieve?
Ralph Wessel BArch
Software Engineer Speckle Systems
Oleg
I want complex (multiwindow) modeless dialogs, like the GDL object editor.
Palettes differ at event messages and behaviour.
I opened modeless dialog (class derived from ModelessDialog)
using palette's APIPaletteControlCallBackProc callback.
It worked basically, but I had problems ( unhandled exception )
at its closing.
Though I could make something wrong, I assume, that this way is not
quite correct.
Akos Somorjai
ArchiCAD keeps track of the window order internally. In that order, modeless dialogs (e.g. the floor plan window) have a special place, and they also have a quite complex internal registration mechanism, which is not available through the API.
You can do most of the things you need modeless dialogs for from a modal dialog. For example, you can switch between databases. Or maybe you can split the interface interface between modal dialogs and palettes.
HTH,
Akos
Oleg
Akos, thank you for the information.
Akos
When modal dialog is open it is impossible to use a palette or the menu.
The palette almost suitable, however it does not receive DG_MSG_TOPSTATUSCHANGE messages same way as modeless dialog.
Anyway thanks, I shall think more.
PS:
I only reflect on a possible experimental project.
It is like a visual resource editor, it would looks like the VC2003
form editor, but using only GS API for DG Controls and almost platform independent.
For example for GDL UI Script editor or grc dialog editor.
I have made the small prototype of the main design panel with the
purpose of check of technical feasibility.
I hope GS will do what they can in the SDK to support your efforts, Oleg, as this would be a huge benefit to GDL and API coders! 😉
The modal part of it would make the interface a bit non-standard, since any menus/commands would have to be part of the dialog or other palette. But, better strange than not at all! 😉 Good luck and keep us posted.
One of the forum moderators
AC 28 USA and earlier   •   macOS Sequoia 15.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
