2015-10-16
03:32 PM
- last edited on
2023-07-13
03:19 PM
by
Doreena Deng
API_LibPart libPart;
BNZeroMemory (&libPart, sizeof (API_LibPart));
//TODO : Get type of libpart ?
libPart.typeID = APILib_ObjectID;
libPart.location = &destinationFile;
// Register the copied library part file
err = ACAPI_LibPart_Register(&libPart);
if(err == NoError)
// Get the library part
err = ACAPI_LibPart_Get(&libPart);
if(err == NoError)
// GS Doc says to free the location...
if (libPart.location != NULL)
delete libPart.location;
libPart.location = NULL;
// Add parameters/properties for this object
API_LibPartSection section;
BNZeroMemory (§ion, sizeof (API_LibPartSection));
section.sectType = API_SectParamDef;
GSHandle sectionHdl = NULL;
err = ACAPI_LibPart_GetSection(libPart.index, §ion, §ionHdl, NULL);
short nPars = 3;
API_AddParType** addPars = reinterpret_cast<API_AddParType**>(BMAllocateHandle (nPars * sizeof (API_AddParType), ALLOCATE_CLEAR, 0));
if (addPars != NULL)
API_AddParType* pAddPar = &(*addPars)[0];
pAddPar->typeID = APIParT_Mater;
pAddPar->typeMod = 0;
CHTruncate ("mat", pAddPar->name, sizeof (pAddPar->name));
GS::ucscpy (pAddPar->uDescname, L("Tom's Material"));
pAddPar->value.real = 1;
pAddPar = &(*addPars)[1];
pAddPar->typeID = APIParT_Length;
CHTruncate ("len", pAddPar->name, sizeof (pAddPar->name));
GS::ucscpy (pAddPar->uDescname, L("Tom's Length"));
pAddPar->value.real = 2.5;
pAddPar = &(*addPars)[2];
pAddPar->typeID = APIParT_CString;
CHTruncate ("myStr", pAddPar->name, sizeof (pAddPar->name));
GS::ucscpy (pAddPar->uDescname, L("Tom's String parameter"));
GS::ucscpy (pAddPar->value.uStr, L("This is Tom's string"));
double aa = 1.0;
double bb = 1.0;
GSHandle Sect2DHdl = NULL;
err = ACAPI_LibPart_GetSect_ParamDef (&libPart, addPars, &aa, &bb, Sect2DHdl, §ionHdl);
API_LibPartDetails details;
BNZeroMemory (&details, sizeof (API_LibPartDetails));
details.object.autoHotspot = false;
err = ACAPI_LibPart_SetDetails_ParamDef (&libPart, sectionHdl, &details);
err = ACAPI_LibPart_UpdateSection (libPart.index, §ion, sectionHdl, NULL);
BMKillHandle (reinterpret_cast<GSHandle*>(&addPars));
BMKillHandle (§ionHdl);
2015-10-19 12:38 PM
gehairing wrote:I think you need to include both the new and additional parameters when you make this call:
I try to modifiy an existing Library part by adding some parameters.
After running this code on a valid library part the library part is no more valid. In the Library Part dialog there are messages indicating that the 2D symbol and 3D symbol are not valid.
Do you have any idea what i am doing wrong ?
err = ACAPI_LibPart_SetDetails_ParamDef (&libPart, sectionHdl, &details);Your existing code will be setting the library part to have only the 3 parameters in
2015-10-19 01:32 PM
2015-10-19 02:45 PM
// Set parameters to the given libPart
void TestSetParameters(const API_LibPart& libPart)
GSErrCode err = ACAPI_LibPart_GetSection(libPart.index, §ion, §ionHdl, NULL);
When is use this code i have the problem :// Set parameters to the given libPart
short nPars = 1;
GS::ucscpy (pAddPar->uDescname, L("Tom's testing parameter"));
double aa = 1.0;
double bb = 1.0;
This is only testing code based on code i found in the Libpart_test project.2015-10-19 03:25 PM
gehairing wrote:There is a marked difference between your 2 examples. Consider the contents of
When i use following code i have no problems at all :
When i create a LibPart i have no problems at all.
err = ACAPI_LibPart_UpdateSection (libPart.index, §ion, sectionHdl, NULL);In the first example,
2015-10-19 03:45 PM
2015-10-19 04:23 PM
gehairing wrote:The code you've written is almost right. Try getting the existing parameters with
Thanks for your reply.
I thought getting the current section with GetSection and adding the new data with GetSect_ParamDef would update the section with the new data. That's what i understand after reading the API doc. But my english is not so good so i probably misunterstood this.
Do you have an idea how i can :
- Get actual parameters,
- Add a few new ones,
- Set all back again.
2015-10-19 04:36 PM
static void DumpParameters (Int32 libInd, API_LibTypeID typeID)
double a, b;
Int32 addParNum, i, ind, i1, i2;
API_AddParType **addPars;
double value;
char *valueStr;
GSErrCode err;
err = ACAPI_LibPart_GetParams (libInd, &a, &b, &addParNum, &addPars);
if (err) return;
for (i = 0; i < addParNum; i++)
if ((*addPars).typeMod == API_ParSimple)
ACAPI_WriteReport ((*addPars).name, false);
else
ind = 0;
for (i1 = 1; i1 <= (*addPars).dim1; i1++)
for (i2 = 1; i2 <= (*addPars).dim2; i2++)
if ((*addPars).typeID != APIParT_CString)
value = (Int32) ((double *) *(*addPars).value.array) [ind];
valueStr = NULL;
ind ++;
} else
value = 0.0;
valueStr = *(*addPars).value.array + ind;
ind += strlen (valueStr) + 1;
ACAPI_WriteReport (valueStr, false);
ACAPI_DisposeAddParHdl (&addPars);
Called this method to dump all parameters before my code :A B ZZYZX AC_show2DHotspotsIn3D ac_bottomlevel ac_toplevel showerType services matFinish SKU gs_2D_representation gs_cont_pen gs_fill_type gs_fill_pen gs_back_pen gs_list gs_list_cost gs_list_manufacturer gs_list_note gs_list_location gs_list_accessories FM_Type iFMType FM_InventoryNumber FM_SerialNumber FM_ProductionYear FM_ObjectWeight FM_ObjectWeightUnit gs_list_custom1 gs_list_custom2 gs_list_custom3 gs_list_custom4 gs_list_custom5 gs_3D_representation gs_detlevel_3D gs_shadow doorOpenThen i run this code (the same as in my previous message) to "add" a parameter :
short nPars = 1;
double aa = 1.0;
double bb = 1.0;
Then run the dump code again :A B ZZYZX AC_show2DHotspotsIn3D ac_bottomlevel ac_toplevel gs_2D_representation gs_cont_pen gs_fill_type gs_fill_pen gs_back_pen gs_list gs_list_cost gs_list_manufacturer gs_list_note gs_list_location gs_list_accessories FM_Type iFMType FM_InventoryNumber FM_SerialNumber FM_ProductionYear FM_ObjectWeight FM_ObjectWeightUnit gs_list_custom1 gs_list_custom2 gs_list_custom3 gs_list_custom4 gs_list_custom5 mat"mat" is the one i "added".
2015-10-19 04:46 PM
gehairing wrote:I suspect that all the parameters before 'mat' are required for the object subtype, so ARCHICAD automatically injects them. So your original list is destroyed and replaced with the subtype parameters and the 1 you added.
Thanks Ralph. I'll try to find how to do what you've explained.
After my previous message i have tried following :
Creating a "dump" code :
(completely based on sample code i found in the API doc)
So It seem's to me that i have lost (or destroyed or whatever)some parameters but not all.
2015-10-19 05:49 PM
static void AddParameterTest (const API_LibPart& libPart)
GSErrCode err;
if (err) return;
double a, b;
Int32 addParNum, i;
err = ACAPI_LibPart_GetParams (libPart.index, &a, &b, &addParNum, &addPars);
if (err) return;
// Create enough space for all parameters
Int32 myParameterCount = 1;
short nPars = addParNum + myParameterCount;
API_AddParType** newAddPars = reinterpret_cast<API_AddParType**>(BMAllocateHandle (nPars * sizeof (API_AddParType), ALLOCATE_CLEAR, 0));
// Copy all parameters
(*newAddPars) = (*addPars);
// Add our new parameter
API_AddParType* pAddPar = &(*newAddPars)[nPars-1];
// Build a section handle with all parameters
err = ACAPI_LibPart_GetSect_ParamDef (&libPart, newAddPars, &a, &b, NULL, §ionHdl);
BMKillHandle (reinterpret_cast<GSHandle*>(&newAddPars));
// Update our section...
