Window/Door Heigth/Width change
I would like to change w/h of an existing window or set up default tool with proper w/h. I thought it will be an easy thing. But it seem more tricky thing.
Mostly I was trying to change API_OpeningBaseType parameters based on Do_ChangeElem form Element_test. But in the case of empty opening, it doesn't work. I case of Window it detaches opening from LibPart - there are two sets of points for opening and for LibPart.
I was also trying to change GDL properties - A and B in particluar. But not much achieved here only errors about the inconsistency of data.
So my question is which path is proper:
- change only opening data in element
- change GDL properties and opening elements
Are there any other parameters to change?
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
I've just checked it with this code (simplified version of UpdateOneWindow function from the Element_Test/Src/Element_Modify.cpp):
static void     UpdateOneWindow (const API_Guid& guid)
    API_Element     element = {};
    API_Element     mask = {};
    GSErrCode       err;
    element.header.guid = guid;
    err = ACAPI_Element_Get (&element);
    if (err == NoError) {
        ACAPI_ELEMENT_MASK_CLEAR (mask);
        ACAPI_ELEMENT_MASK_SET (mask, API_WindowType, openingBase.width);
        ACAPI_ELEMENT_MASK_SET (mask, API_WindowType, openingBase.height);
        element.window.openingBase.width *= 2.0;
        element.window.openingBase.height += 0.2;
        err = ACAPI_Element_Change (&element, &mask, nullptr, 0, true);
It worked for empty openings also.
Yes, you should check the verticalLink field of the API_OpeningBaseType structure. The sill or header of the window/door can be linked to the top/bottom of the wall, so the distance can be fix.
Tibor wrote:
UpdateOneWindow
Thanks, I have missed this one somehow and tried the version with markers based on Ext .
So I assume that in case of changing Windows/Doors size and position there is no need to manipulate GDL properties and therefore memo of the element. Is that right?
I end up with changing the GDL parameters because when I created a new window with changed W/H it ends up "detached from the opening" so element it didn't fit the opening. However when I opened Window settings and clicked OK window is updated and its fine. After your suggestion, I do create a new window and then I call Element_Chanege to "update" element and this works. Is there any other way to force AC to refresh without calling another element based operation?
Tibor wrote:
verticalLink
Thanks a lot. I figured out that Value is stored in lower parameter but could find linking props.
I have one more question regarding EmptyOpenings. In Window documentation, there is a statement that libind with value 0 creates an empty opening. But unfortunately, when I tried to Create such an object it works error that params are inconsistent. Shall it works ? in most cases EmptyOpening has own libind in Library anyway.
