2025-02-09 07:33 PM
Hello all,
Please, In TUBE or TUBE{2}, Is there a flag which allows displaying diagonal when TUBE change direction to 90 degrees?
Image attache show the TUBE preview, and I marked in red the lines I want to keep visible in 3D, elevations etc.
Thanks in advance.
2025-02-10 12:26 PM
muril00ng, You can control the visiility edgelines in many ways by mask value
Please, read GDL manual on page 93:
TUBE n, m, mask,
u1, w1, s1,
un, wn, sn,
x1, y1, z1, angle1,
xm, ym, zm, anglem
mask: controls the existence of the bottom and top polygons’ surfaces and edges.
mask = j1 + 2*j2 + 16*j5 + 32*j6 + 64*j7 + 128*j8 + 512*j10 + 1024*j11 + 2048*j12 + 4096*j13,
where each j can be 0 or 1.
j1: base surface is present,
j2: end surface is present,
j5: base edges (at x2, y2, z2) are visible,
j6: end edges (at xm-1, ym-1, zm-1) are visible,
j7: cross-section edges are visible, surface is articulated,
j8: cross-section edges are sharp, the surface smoothing will stop here in OpenGL and rendering,
j10: base edges participate in line elimination (Compatibility: introduced in Archicad 23.),
j11: end edges participate in line elimination (Compatibility: introduced in Archicad 23.),
j12: longitudinal edges (which connect cross sections) participate in line elimination (Compatibility: introduced in Archicad 23.),
j13: edges of cross sections participate in line elimination (Compatibility: introduced in Archicad 23.).
si: status of the lateral edges.
0: lateral edges starting from the node are all visible,
1: lateral edges starting from the node are used for showing the contour.
2: when using Archicad or Z-buffer Rendering Engine and setting Smooth Surfaces, the lateral edge belonging to this point defines a
break. This solution is equivalent to the definition of additional nodes. The calculation is performed by the compiler. With other rendering
methods, it has the same effect as using 0.
2025-02-10
02:59 PM
- last edited on
2025-02-11
05:25 PM
by
Thanks Pertti,
I 've tried that already, however diagonals don't appear.
Here's the code:
!!! A = 0.300
!!! B = 0.250
material 18
TUBE 5, 6, 1+2+16+32+64,
!!! profile
0, 0, 0,
0.040, 0, 0,
0.040, 0.010, 0,
0, 0.010, 0,
0, 0, 0,
!!! path
0,-0.2,0,0,
0,0,0,0,
0,B,0,0,
A,B,0,0,
A,0,0,0,
A,-0.2,0,0
2025-02-19 08:49 AM
I have come across the same issue.
Seems that the surfaces that are co-planar (i.e the horizontal surfaces), will have no join line at the corner.
But the other surfaces at the corners will show a join line because they are at an angle to each other.
I have not found any of the masking or status values that can show that horizontal join.
2025-02-19 08:59 AM
Ok, then we can try to split the tube into peaces.
2025-02-19 09:46 AM
I know what you mean, but that defeats the purpose of it being a tube.
In my case an adjustable polyline object where I can feed the co-ordinates into the TUBE with PUT commands.
2025-02-19 05:30 PM
The advantage of breaking it apart is that when it comes to curves tubes have to be segmented. so looping the tube points initially and segmenting will make that easier if it's something that will eventually need to be used
2025-02-20 02:33 AM
All done with the tube command.
No need to break into individual segments.
