dushyant
Multiple add-ons not loading
Hi
I created two add-ons, each having its own unique 'Local ID', and my developer ID. Each works fine when loaded independently at a time in Archicad 25. But when I try to load both of them in the same instance of Archicad, only one works.
Could it be because of the 32500 resource ID in both the add-ons? I don't see any other similar resource which could cause a clash.
Considering the two add-ons are:
1. Addon-A
2. Addon-B
Both of the add-ons are palette-based. Both of their menus get loaded. But only the palette of Addon-B opens on clicking its menu-item.
Addon-A's palette never opens when Addon-B is loaded (palette-B open or not open, in either case).
Addon-B uses BrowserControl.
Sometimes Archicad crashes when I try to open the palette of Addon-A.
Addon-A's palette does not open even when Addon-B is unloaded and the project is reloaded. It only opens when Archicad is restarted (after unloading Addon-B).
Why is this happening?
Thanks.
1 Solution
Viktor Kovacs
I'd check if the guids are different for the palettes in the DG::Palette constructor call.
Go to post
4 Replies 4
Viktor Kovacs
dushyant
Yes, you are right, the guids of both the palettes are the same.
I don't know how to create a guid, so I copied.
How do you create a new guid for a palette?
Viktor Kovacs
With any guid generator, for example this one: https://www.guidgenerator.com/
dushyant
Thanks a lot! That solved it!
