‎2010-11-18
01:36 AM
‎2024-09-09
10:55 AM
Doreena Deng
‎2010-11-18 01:33 PM
Hoa wrote:Have you tried using
I am trying to change the subtype of a library part using the ACAPI_LibPart_UpdateSection function as the following code segment:
‎2010-11-19 12:47 AM
Have you tried using APIEnv_OverwriteLibPartID and ACAPI_LibPart_Create to change the object?Ralph,
‎2010-11-19 11:22 AM
Hoa wrote:Not if you use it with
Thanks for your suggestion, but I can not use the ACAPI_LibPart_Create, because it will change the GUID of the object.
‎2010-11-21 11:29 PM
‎2010-11-23 04:48 AM
