2024-03-25 03:50 PM - edited 2024-03-28 12:57 PM
Dear Community.
I am a newbie in my use of the Archicad C++ API. I have been trying to use the ACAPI_ProjectSetting_SetPreferences() and ACAPI_ProjectSetting_GetPreferences() to set and get Project Settings (as it relates to ZONE preferences) but even though my code builds without any error, I still cannot confirm whether the code has executed its intended purpose. Because while using the ACAPI_ProjectSetting_GetPreferences() it returns values that do not tally with my settings. Please any good counsel will be appreciated. Below is the code I am using. The return values I get are zonePrefs.nichDoorFlag = true;
zonePrefs.nichWindFlag = true;
zonePrefs.nichDepthFlag = true;
zonePrefs.nichSizeFlag = true;
zonePrefs.nichDepth = -925596313493178000000000000000;
zonePrefs.nichSize = -925596313493178000000000000000;
/// CHANGING ZONE PREFERENCES AND CHECKING ENDS HERE
// Consolidated error handling function
void HandleError(GSErrCode errorCode, const char* errorMessage) {
if (errorCode != NoError) {
ACAPI_WriteReport(errorMessage, true);
// Function to define the setPreference function
GSErrCode ACAPI_ProjectSetting_SetPreferences(API_PrefsTypeID prefsTypeID, const void* prefs) {
// Check if the prefs pointer is valid
if (prefs == nullptr) {
HandleError(APIERR_BADPARS, "Error: Invalid preferences pointer.");
return APIERR_BADPARS;
// Check if the prefsTypeID is valid
if (prefsTypeID != APIPrefs_ZonesID) {
HandleError(APIERR_BADID, "Error: Invalid preferences type ID.");
return APIERR_BADID;
// Write a report to indicate that zone preferences are being set
ACAPI_WriteReport("Setting zone preferences...", true);
return NoError;
//function definition for getPreference
GSErrCode ACAPI_ProjectSetting_GetPreferences(API_PrefsTypeID prefsTypeID, const void* prefs) {
ACAPI_WriteReport("Error: Invalid preferences pointer.", true);
ACAPI_WriteReport("Error: Invalid preferences type ID.", true);
return NoError;
// Function to write zone preferences to reports
void WritePreferences(const API_ZonePrefs& zonePrefs) {
// Convert boolean values to string representation
const char* doorFlagStr = zonePrefs.nichDoorFlag ? "true" : "false";
const char* windFlagStr = zonePrefs.nichWindFlag ? "true" : "false";
const char* depthFlagStr = zonePrefs.nichDepthFlag ? "true" : "false";
const char* sizeFlagStr = zonePrefs.nichSizeFlag ? "true" : "false";
// Convert double values to UniString
GS::UniString depthStr = GS::UniString::Printf("%lf", zonePrefs.nichDepth);
GS::UniString sizeStr = GS::UniString::Printf("%lf", zonePrefs.nichSize);
// Write preferences to reports
ACAPI_WriteReport("Nich Door Flag: " + GS::UniString(doorFlagStr), true);
ACAPI_WriteReport("Nich Wind Flag: " + GS::UniString(windFlagStr), true);
ACAPI_WriteReport("Nich Depth Flag: " + GS::UniString(depthFlagStr), true);
ACAPI_WriteReport("Nich Size Flag: " + GS::UniString(sizeFlagStr), true);
ACAPI_WriteReport("Nich Depth: " + depthStr, true);
ACAPI_WriteReport("Nich Size: " + sizeStr, true);
// Function to set zone preference
GSErrCode SetZonePreferences() {
// Define the zone preferences structure and initialize it with the desired values
API_ZonePrefs zonePrefs;
zonePrefs.nichSizeFlag = false;
zonePrefs.nichDepth = 0.130;
zonePrefs.nichSize = 0.10;
// Set the preferences using ACAPI_ProjectSetting_SetPreferences
GSErrCode err = ACAPI_ProjectSetting_SetPreferences(APIPrefs_ZonesID, &zonePrefs);
if (err != NoError) {
HandleError(err, "Error: Failed to set zone preferences.");
else {
ACAPI_WriteReport("Zone preferences set successfully.", true);
return err;
// Function to get and display zone preference
void DisplayZonePreferences() {
// Define the zone preferences structure to store retrieved preferences
// Get the zone preferences using ACAPI_ProjectSetting_GetPreferences
GSErrCode err = ACAPI_ProjectSetting_GetPreferences(APIPrefs_ZonesID, &zonePrefs);
HandleError(err, "Error: Failed to get zone preferences.");
return;
WritePreferences(zonePrefs);
Solved! Go to Solution.
2024-04-09 04:49 PM
Please find below the correct code; the basic problem was that you didn't call the API to set/get the preferences, just your own functions.
Best, Akos
void *locPrefs = const_cast<void*>(prefs);
GSErrCode err = ACAPI_ProjectSetting_SetPreferences (locPrefs, APIPrefs_ZonesID);
HandleError(err, "Error: Failed to set Zone preferences.");
return NoError;
GSErrCode ACAPI_ProjectSetting_GetPreferences(API_PrefsTypeID prefsTypeID, void* prefs) {
GSErrCode err = ACAPI_ProjectSetting_GetPreferences (prefs, APIPrefs_ZonesID);
HandleError(err, "Error: Cannot get Zone preferences.");
return NoError;
// Load the current values
ACAPI_ProjectSetting_GetPreferences (&zonePrefs, APIPrefs_ZonesID);
// Modify those that we need
else {
return err;
return;
2024-04-09 04:49 PM
Best, Akos
return NoError;
return NoError;
else {
return err;
return;
2024-04-10 04:04 PM
Thank you @Akos Somorjai . I have been waiting for any meaningful help. I tried the code you suggested. It built without any errors, but the Archicad 26 crashing when ever I call the SetPreferences function. Here is the code I used. Maybe you can guide me with specifics. I am concerned because I can not find any example in the documentation. Thank you for your time.
void* locPrefs = const_cast<void*>(prefs);
GSErrCode err = ACAPI_ProjectSetting_SetPreferences(APIPrefs_ZonesID, locPrefs);
return NoError;
GSErrCode err = ACAPI_ProjectSetting_GetPreferences(prefs, APIPrefs_ZonesID);
return NoError;
ACAPI_ProjectSetting_GetPreferences(&zonePrefs, APIPrefs_ZonesID);
zonePrefs.nichDepth = 0.13;
else {
return err;
void DisplayZonePreferences2() {
return;
// Menu command handler
// This function handles menu commands and performs the appropriate actions.
static GSErrCode MenuCommandHandler(const API_MenuParams* menuParams) {
switch (menuParams->menuItemRef.menuResID) {
case AddOnMenuID:
switch (menuParams->menuItemRef.itemIndex) {
case AddOnCommandID:
DisplayZonePreferences2();
SetZonePreferences();
break;
break;
return NoError;
2024-04-11 11:23 AM
Hi Apollos,
The code I added was for Archicad 27, not Archicad 26. Your code is strange because it uses the function names from Archicad 27 API. Which devkit version do you use, along with which Archicad version?
Best, Akos
2024-04-11 12:59 PM
Dear @Akos Somorjai,
Thank you for your time and counsel. I apologise for failing to inform you that I am using Archicad 26. But as you suggested I will try and use the Archicad 27. Maybe that is why it is crashing. I use Archicad 26 with its Developer Kit. Please do you have any other option for Archicad 26? Even though I will try it on Archicad 27 (& its developer kit) and will give you an update. Once again thank you.
2024-04-11 01:29 PM
Dear @Apollos ,
Unfortunately, this is not possible in Archicad 26 because the SetPreferences function is available from Archicad 27 only.
Sorry, Akos
2024-04-29 04:19 PM
Dear @Akos , I am grateful. I installed Archicad 27 and its API DevKit. The code worked. Thank you. I hope to learn more from you. Best regards. Apollos
2024-04-29 10:42 PM
Dear @Akos Somorjai ,
Please is there any function to Update Zones in Archicad 27 API?
