Does anybody know if it is possible to refresh the 3D view after positioning the camera? If I set the camera from my addon I can do a rebuild, but that can cost a lot in case of having larger models. The redraw feature of the API does not seem to work for this case, so far I did not find any solution just to call rebuild. Sure when I move manually the model there is no rebuild all the time, otherwise the 3d performance would be really bad even on smaller models, not just on large ones.
Thanks!
