Archicad C++ API
Return the gsm filename as string associated with an element
Emkave
Good day again, had somebody have the idea of how I could return a string that would contain a GSM filename, that an element I selected is associated with, via the API?
I was looking into the API functions that were related to LibPart but so far nothing useful was found, so I decided to post this thread here just in case if anyone else had had to deal with it before.
Thank you!
Apologies. I have found the solution. The solution was stored inside of an API_LibPart object; the data that I was searching for was located at:
API_LibPart::file_UName.
LChen
Hi, sorry I'm not so clear what did you mean a GSM associates with an element, did you mean, like the case of Label object?
