Friday
I'm new to this world, and was wondering how compatibility is working between SDK versions and Archicad versions.
For example, I have Archicad 27.4060.
I built my plugin with SDK 27.3001 and 27.6003 and they both worked with my version of Archicad.
So can I use only one version of SDK for a major version and it will work for any Archicad of this version ? Or is there a compatibility table I've not yet found ?
Thanks in advance.
Solved! Go to Solution.
Friday
You can always build your add-on with the latest Development kit, it will be compatible with Archicads with the same major version. We publish a new Development kit with bigger updates.
Best regards,
Tamás
Friday
Best regards,
Tamás
yesterday
I don't know if I missed the info, but the doc could be a little more clear about this point.
Thanks for your quick answer,
Best regards
