‎2017-04-21
07:44 AM
‎2023-07-12
08:44 PM
Doreena Deng
GSErrCode err = NoError;
API_DatabaseInfo db;
BNZeroMemory (&db, sizeof (API_DatabaseInfo));
db.typeID = APIWind_FloorPlanID;
API_NavigatorView view;
API_NavigatorItem parent;
API_NavigatorItem item;
API_NavigatorItem** items = NULL;
BNZeroMemory (&item, sizeof (API_NavigatorItem));
item.itemType = API_StoryNavItem
item.mapId = API_PublicViewMap;
err = ACAPI_Environment (APIEnv_SearchNavigatorItemID, &item, &items, NULL);
if (err != NoError || items == NULL)
return;
char str[256];
Int32 num;
Int32 n = BMhGetSize ((GSHandle) items) / sizeof (API_NavigatorItem);
ACAPI_WriteReport ("Stories of View Map:", false);
for (Int32 i = 0; i < n; i++) {
sprintf (str, "%s", (*items).name);
ACAPI_WriteReport (str, false);
BNZeroMemory (&parent, sizeof (API_NavigatorItem));
parent.mapId = API_PublicViewMap;
err = ACAPI_Environment (APIEnv_GetNavigatorParentItemID, (*items).guid, &parent, NULL);
sprintf (str, " - parent name: %s", parent.name);
err = ACAPI_Environment (APIEnv_GetNavigatorChildNumID, &parent, &num, NULL);
sprintf (str, " - number of children of the parent: %d", num);
BNZeroMemory (&view, sizeof (API_NavigatorView));
err = ACAPI_Environment (APIEnv_GetNavigatorViewID, &((*items)), &view, NULL);
if (view.saveLaySet) {
if (view.layerCombination[0] != 0)
sprintf (str, " - Layer combination: %s", view.layerCombination);
else
sprintf (str, " - Layers individual");
} else {
sprintf (str, " - none layers");
BMhKill ((GSHandle*) &view.layerStats);
BMhKill ((GSHandle *) &items);
‎2017-04-21 10:12 AM
Ben wrote:Have you tried varying this line:
Hi All
I am trying to create an addon that searches through all navigator items and changes various view settings. All is working well but I have found the search is only working for floor plan and perspective view types.
I am changing this line of code
item.itemType = API_StoryNavItem;
to this
item.itemType = API_SectionNavItem
which will work with floor plans and perspectives - but nothing else??
db.typeID = APIWind_FloorPlanID;That line is directing the search toward the floor plan database.
‎2017-04-21 12:05 PM
‎2017-04-23 05:54 PM
Ben wrote:Hi Ben,
Hi Ralph
Yes I tried that. Interestingly API_PerspectiveNavItem and API_StoryNavItem both work regardless of how db.typeID is set.
so if I do this
item.itemType = API_SectionNavItem; // API_StoryNavItem;
db.typeID = APIWind_SectionID;
It does not help
Thanks for the reply but still no luck
‎2017-04-24 04:12 AM
‎2017-04-24 09:00 AM
‎2017-04-24 12:32 PM
‎2017-04-26 08:02 AM
‎2017-05-10 01:08 PM
static void MakeTree (short dialogID, short treeItem, Int32 parent, const API_Guid& guid, GS::PagedArray<Int32>& itemsArray, API_NavigatorMapID mapId)
item.guid = guid;
item.mapId = NavigatorTestGlobals::Instance ().GetNavigatorMapID ();
GSErrCode err = ACAPI_Environment (APIEnv_GetNavigatorChildrenItemsID, &item, &items);
return;
Int32 n = BMhGetSize ((GSHandle)items) / Sizeof32 (API_NavigatorItem);
if ((*items).itemType == API_ScheduleNavItem) {
API_NavigatorItem** items2 = nullptr;
char msgStr[256];
sprintf (msgStr, "GUID: %s, GUID2: %s, name: %s\n",
APIGuid2GSGuid ((*items).guid).ToUniString ().ToCStr ().Get (),
APIGuid2GSGuid ((*items).guid2).ToUniString ().ToCStr ().Get (),
(*items).name);
ACAPI_WriteReport (msgStr, false);
(*items).mapId = mapId;
err = ACAPI_Environment (APIEnv_SearchNavigatorItemID, &(*items), &items2);
Int32 nn = BMhGetSize ((GSHandle) items2) / Sizeof32 (API_NavigatorItem);
for (Int32 ii = 0; ii < nn; ii++) {
sprintf (msgStr, "GUID: %s, Name: %s, \n",
APIGuid2GSGuid ((*items2)[ii].guid).ToUniString ().ToCStr ().Get (), (*items2)[ii].name);
BMhKill ((GSHandle *) &items2);
Int32 newItem = InsertTreeItem (dialogID, treeItem, parent, (*items).name, (*items).uiId, (*items).guid, (*items).itemType);
if (newItem != 0) {
itemsArray.Push (newItem);
MakeTree (dialogID, treeItem, newItem, (*items).guid, itemsArray, mapId);
‎2017-05-18 09:34 AM
