Archicad C++ API
[SOLVED] Automatically starting add-on(notification handler)
Hi
Is it possible to start add-on automatically?
I want to use some events (APINotify_New, APINotify_Open, APINotify_Close).
I've added
GSErrCode __ACENV_CALL	Initialize (void)
    GSErrCode err = ACAPI_Notify_CatchProjectEvent (API_AllProjectNotificationMask, NotificationHandler);
on Initialize and I've added notification handler:
static GSErrCode __ACENV_CALL    NotificationHandler (API_NotifyEventID notifID, Int32 param)
    switch (notifID) {
        case APINotify_New:
        case APINotify_Open:
Problem is with Initialize method, it isn't executed automatically after ArchiCAD starts.
If I add menu command handler, Iinitialize method will be executed on user's menu action (first time).
Is it possible to run add-on automatically (start Notification handler) without user action?
Thanks
Lukasz
Tibor Lorantfy
Graphisoft Alumni
Hi Lukasz,
Please check the return type of your CheckEnvironment function!
I think you should return APIAddon_Preload in CheckEnvironment function. That way Initialize method will be executed when ArchiCAD starts.
Using ACAPI_KeepInMemory could be necessary also.
Regards,
Tibor
Great! Thanks Tibor. It is working
Best Regards
Lukasz
