Erenford
[SOLVED] DG Message when palette dialog is docked?
Is there a DG Message in callback when a palette dialog is docked? Or know when docking location changes/what the docked location is?
What I want to do is to re-arrange my dialog items whenever the dialog is docked according to its docked location.
For ex. I have a palette with 2 list box: if I docked it on top, it will look like the 2nd screen. If I docked it on left/right, instead of the one in the 3rd screen it'll move the 2nd list box and put it at the bottom of the 1st list box, taking less space than if I didn't re-arrange it.
Is this possible?
1 Reply 1
Tibor Lorantfy
Dear ArchiCAD-Talk forum members,
today I implemented a "new API function" just for you:
ACAPI_Notify_CatchDockStateChanged
With this function you can catch dock/undock events and docked title orientation changed events also.
Interface:
typedef struct {
	short	dialId;
	bool	isDocked;
	bool	isDockedTitleHorizontal;
} API_DockStateInfo;
typedef void	__ACENV_CALL	APIDockStateChangedCallBackProc (short dialId, API_DockStateInfo dockStateInfo);
void	ACAPI_Notify_CatchDockStateChanged (short dialId, APIDockStateChangedCallBackProc *callBackProc);
Implementation:
	if (DGGetDialogType (dialId) == DG_DT_PALETTE) {
		static GS::HashTable<short, API_DockStateInfo> dockStateInfos;
		API_DockStateInfo actDockStateInfo;
		actDockStateInfo.dialId = dialId;
		GS::Guid paletteGuid;
		DGGetPaletteGuid (dialId, &paletteGuid);
		actDockStateInfo.isDocked = DGIsPaletteDocked (paletteGuid);
		short hFrameSize;
		short vFrameSize;
		short hClientSize;
		short vClientSize;
		DGGetDialogSize (ACAPI_GetOwnResModule (), dialId, DG_ORIGFRAME, &hFrameSize, &vFrameSize);
		DGGetDialogSize (ACAPI_GetOwnResModule (), dialId, DG_ORIGCLIENT, &hClientSize, &vClientSize);
		actDockStateInfo.isDockedTitleHorizontal = (hFrameSize - hClientSize > vFrameSize - vClientSize);
		API_DockStateInfo prevDockStateInfo;
		if (!dockStateInfos.Get (dialId, &prevDockStateInfo)									||
			prevDockStateInfo.isDocked					!= actDockStateInfo.isDocked				||
			prevDockStateInfo.isDockedTitleHorizontal	!= actDockStateInfo.isDockedTitleHorizontal)
			dockStateInfos.Put (dialId, actDockStateInfo);
			callBackProc (dialId, actDockStateInfo);
Example:
void	__ACENV_CALL DockStateChangedCallBack (short dialId, API_DockStateInfo dockStateInfo)
	char buffer[512];
	sprintf (buffer, "DockStateChanged: dialId=%d, isDocked=%d, isDockedTitleHorizontal=%d", dialId, dockStateInfo.isDocked, dockStateInfo.isDockedTitleHorizontal);
	ACAPI_WriteReport (buffer, true);
	// Handle dock state changed event as you want!
// -------------------------------------- With C++ style Palette: -----------------------------------------------------
// Define the following function in the dialog's observer class:
		virtual void PanelIdle (const DG::PanelIdleEvent&);
void	MyDialogObserver:PanelIdle (const DG::PanelIdleEvent& /*ev*/)
	ACAPI_Notify_CatchDockStateChanged (myDialog->GetId (), DockStateChangedCallBack);
	// myDialog is a pointer to the dialog
// ---------------------------------------- With C style Palette: -----------------------------------------------------
// In the dialog's callback function:
//		at the end of DG_MSG_INIT message handling:
			DGEnableMessage (dialID, DG_ALL_ITEMS, DG_MSG_NULL);
			break;
		case DG_MSG_NULL:
			ACAPI_Notify_CatchDockStateChanged (dialID, DockStateChangedCallBack);
			break;
Feel free to use this and please report me here if you have any problem about this function!
Regards,
Tibor
