[SOLVED] Geometry::Polygon2D to Polygon2DData in AC18?
I used following code to convert Geometry::Polygon2D to Geometry::Polygon2DData in AC 17.
Geometry::Polygon2D polygon2D;
Geometry::Polygon2DData polygon2DData;
polygon2D.Convert(polygon2DData);
This Convert function is removed.
Any ideas how to do the conversion in AC18?
This is part of the following process:
1. List of VectorImage iterated.
2. Each VectorImage with item_Typ SyHatch is converter using ConvSyHatchToPolygon to Geometry::MultiPolygon2D.
3. MultiPolygon2D(s) are iterated.
4. Each Geometry::Polygon2D in MultiPolygon2D is converted to Geometry::Polygon2DData.
5. An union is made from all Polygon2DData using Geometry::UnifyPolygon2DData.
6. The coordinates are extracted from the union using Polygon2DDataToPolyline
-Matti
2 Replies 2
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
Hi Matti,
use Geometry::ConvertPolygon2DToPolygon2DData function to convert Geometry::Polygon2D to Geometry::Polygon2DData in AC 18.
Geometry::InitPolygon2DData (&polygon2DData);
Geometry::ConvertPolygon2DToPolygon2DData (polygon2DData, polygon2D);
It could be faster if you use Unify method in MultiPolygon2D before conversions:
4. An union is made from MultiPolygon2D using multiPolygon2D.Unify ()
5. Each Polygon2D in result MultiPolygon2D is converted to Polygon2DData by Geometry::ConvertPolygon2DToPolygon2DData
Regards,
Tibor
Thanks!
