[SOLVED] German letters not showing properly
Hello again,
I'm tryging to create a new attribute with name "Sto-Dämmplatte Top32", but the ä symbol seems to break like in the image bellow. What could be the possible reason for that? My code is something like that:
const char * name = vectorit->name.c_str();
strcpy (attrib.header.name, name);
Thanks in advance,
Julian C.
4 Replies 4
Ralph Wessel
I think that's a text encoding problem. You probably want to set the attribute name using a GS::UniString, in which case you would set uniStringNamePtr rather than name in the attribute header. That should ensure the string encoding is correctly interpreted and preserved.
Ralph Wessel BArch
Central Innovation
 GS::UniString uniName (vectorit->name.c_str());
 attrib.header.uniStringNamePtr = &uniName;
 WriteReport("uniname is %s", uniName.ToCStr().Get());
This is my code, but still when created in Archicad the name looks like this -"Sto-D√§mmplatte Top32". Strangely when I open my console.app it is logged as it should be: "uniname is Sto-Dämmplatte Top32"...
What else could it be? Just for the record I'm working on xcode 8.3.2
Ralph Wessel
What is the encoding of vectorit->name? You need to pass the encoding type to the constructor of GS::Stringor it may interpret it incorrectly, e.g. if the encoding is UTF-8:
 GS::UniString uniName (vectorit->name.c_str(), CC_UTF8);
Ralph Wessel BArch
Central Innovation
Thanks Ralph!!! Everything works perfect now. Issue resolved ))
