Archicad C++ API
[SOLVED] German letters not showing properly
Hello again,
I'm tryging to create a new attribute with name "Sto-Dämmplatte Top32", but the ä symbol seems to break like in the image bellow. What could be the possible reason for that? My code is something like that:
const char * name = vectorit->name.c_str();
strcpy (attrib.header.name, name);
Thanks in advance,
Julian C.
4 REPLIES 4
Ralph Wessel
Mentor
I think that's a text encoding problem. You probably want to set the attribute name using a GS::UniString, in which case you would set uniStringNamePtr rather than name in the attribute header. That should ensure the string encoding is correctly interpreted and preserved.
Ralph Wessel BArch
Software Engineer Speckle Systems
 GS::UniString uniName (vectorit->name.c_str());
 attrib.header.uniStringNamePtr = &uniName;
 WriteReport("uniname is %s", uniName.ToCStr().Get());
This is my code, but still when created in Archicad the name looks like this -"Sto-D√§mmplatte Top32". Strangely when I open my console.app it is logged as it should be: "uniname is Sto-Dämmplatte Top32"...
What else could it be? Just for the record I'm working on xcode 8.3.2
Ralph Wessel
Mentor
What is the encoding of vectorit->name? You need to pass the encoding type to the constructor of GS::Stringor it may interpret it incorrectly, e.g. if the encoding is UTF-8:
 GS::UniString uniName (vectorit->name.c_str(), CC_UTF8);
Ralph Wessel BArch
Thanks Ralph!!! Everything works perfect now. Issue resolved ))
