We value your input!
Archicad C++ API
[SOLVED] How to dynamically load a picture
Hello
I need to have a picture in my add-on dialog.
Is there a way to dynamically load pictures from file system.
Tibor Lorantfy
you can use GX::Image to dynamically load pictures from file.
// Example code to dynamic load image:
IO::Location locationToPic ("<path string to the picture file>");
const void* dgPicture = GX::Image (locationToPic).ToDGPicture ();
DGSetItemImage (<DIALOG_ID>, <PIC_ITEM_ID>, DG::Picture (dgPicture));
// or with C++ interface DG::PictureItem use SetPicture (DG::Picture (dgPicture))
// In the dialog's resource you must define a Picture item and should define a default picture in the fix GRC
'GBMP'	<DEFAULT_PIC_RESID>	"default_picture" {
	"default_picture"
'GDLG'  <DIALOG_ID>    Modal    0    0  210  210  "Dialog with picture" {
/* [<PIC_ITEM_ID>] */ Picture			  10   10   200   200  <DEFAULT_PIC_RESID>	ClientEdge
Best Regards,
Tibor
Thank you for the answer Tibor.
This is what I needed!
