[SOLVED] How to find element by IFC Guid
Hi
My goal is to find element by IFC Guid
I have no choice to find by TagID because I'm getting IfcGUID from webAPI and I have to search by IFC GUID.
Is there any way to do that ?
Thanks in advance!
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
First you have to convert string IFC guid to API_Guid, after that you can search the elements with the given guid.
Here is an example code for you:
GS::UniString	ifcGuid = "32vZ_y6Kf8bQUeOicmrSnx"; // string IFC Guid
API_Guid		apiGuid;
if (ACAPI_Goodies (APIAny_IFCGuidToAPIGuidID, &ifcGuid, &apiGuid, NULL) == NoError) {
	GS::Array<API_Guid> elements;
	if (ACAPI_Element_GetElemListByIFCIdentifier (NULL, &apiGuid, elements) == NoError) {
		for (GS::Array<API_Guid>::ConstIterator it = elements.Enumerate (); it != NULL; ++it) {
			API_Element	element;
			BNZeroMemory (&element, sizeof (API_Element));
			element.header.guid = *it;
			if (ACAPI_Element_Get (&element) == NoError) {
				// now you have the element
Regards,
Tibor
Thank you very much for the help Tibor.
But I changed a thing in your code in order elements comes not empty
I also pass &apiGuid as first parameter of ACAPI_Element_GetElemListByIFCIdentifier
like this
ACAPI_Element_GetElemListByIFCIdentifier (&apiGuid, &apiGuid, elements)
Thanks
