Archicad C++ API
[SOLVED] Opening text file into add-on
Hi everybody!
I am new to archicad and C++. I am developing the add-on on x-code 8.3.2. The add-on is for my company, which will import materials and build ups from text file. Now I have a struggle and I can't find any method in the API for opening simple file dialog. The closest thing I find is APIIo_​OpenPictureDialogID, but it doesn't suite my needs. Am I missing something here?
All the best, Julian
5 REPLIES 5
Tibor Lorantfy
Hi Julian,
static bool	GetOpenFile (IO::Location*	dloc, const char* fileExtensions, const GS::UniString& filterText)
	if (dloc == nullptr)
		return false;
	FTM::TypeID	retID;
	FTM::FileTypeManager	ftman ("MyManager");
	FTM::FileType			type (nullptr, fileExtensions, 0, 0, 0);
	FTM::TypeID				id = FTM::FileTypeManager::SearchForType (type);
	if (id == FTM::UnknownType)
		id = ftman.AddType (type);
	DG::FileDialog	dlg (DG::FileDialog::OpenFile);						// Open only 1 file
	UIndex	i = dlg.AddFilter (id, DG::FileDialog::DisplayExtensions);
	dlg.SetFilterText (i, filterText);
	if (!dlg.Invoke ())
		return false;
	*dloc = dlg.GetSelectedFile ();
	return true;
// Usage:
IO::Location selectedTextFileLoc;
if (!GetOpenFile (&selectedTextFileLoc, "Text File", "*.txt"))
	return;
This simple GetOpenFile function opens a file dialog for you.
Regards,
Tibor
Hey Tibor,
Thank you very much !!
I have another question and I don't want to open a new thread for it. For debugging purposes I want to log some data. I'm opening the report window from File > Info > Session Report. Is this the right way to open it?
Also I'm using WriteReport_Alert() method, but I only get the popup, without logging the data into the report window of archicad. I am using the demo version of Archicad, so is it possible that ACAPI_WriteReport() doesn't work with the demo version of archicad and doesn't want to write to that file?
Thanks in advance, Julian
Akos Somorjai
Well, depends on where you want to see the log, I would recommend using a simple DBPrintf () call, which writes to the system.log in Console.
ACAPI_WriteReport shouldn't behave differently in the DEMO version, but you can always order a developer license.
Best, Akos
A DBPrintf () call from my add-on doesn't write anything in the system.log ... Is there anything specific that I need to do in order to make it work ?
