[SOLVED] SingleSelListBox header
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2015-09-08
02:39 PM
2023-07-13
03:37 PM
Doreena Deng
2015-09-08
02:39 PM
Hello
How to set up header columns?
I'm doing the following but it shows the first column only
lbNodes.SetHeaderItemCount(5);
lbNodes.SetHeaderItemSize(1, 50);
lbNodes.SetHeaderItemSize(2, 50);
lbNodes.SetHeaderItemSize(3, 50);
lbNodes.SetHeaderItemSize(4, 50);
lbNodes.SetHeaderItemSize(5, 50);
lbNodes.SetHeaderItemText(1, "Name");
lbNodes.SetHeaderItemText(2, "User");
lbNodes.SetHeaderItemText(3, "CPU");
lbNodes.SetHeaderItemText(4, "GPU");
lbNodes.SetHeaderItemText(5, "GPU Load");
lbNodes.AppendItem ();
lbNodes.SetTabItemText(DG::ListBox::BottomItem, 1, "server1");
lbNodes.SetTabItemText(DG::ListBox::BottomItem, 2, "user1");
lbNodes.SetTabItemText(DG::ListBox::BottomItem, 3, "1");
lbNodes.SetTabItemText(DG::ListBox::BottomItem, 4, "2");
lbNodes.SetTabItemText(DG::ListBox::BottomItem, 5, "50%");
Labels:
- Labels:
Add-On (C++)
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-09-09 07:20 PM
2015-09-09
07:20 PM
I think you dont need to use SetHeaderItemCount and SetHeaderItemSize.
Look at SetTabFieldCount and SetTabFieldProperties.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-08-15 09:15 AM
2016-08-15
09:15 AM
I have something like this:
EDIT
I also tried doing as simple as this:
EDIT 2
I tried calling HasHeader() and it returns false whether header flag is set or not. Is this a bug?
SomeTabPage::SomeTabPage(...) : ... lstItem(GetReference(), DG::Rect(), DG::ListBox::VScroll, DG::ListBox::NoPartialItems, DG::ListBox::Header, 25) { // ... const short tabCnt = 5; lstItem.SetTabFieldCount(tabCnt); lstItem.SetPosition(xpos, ypos); lstItem.SetSize(itmWd, itmHt); lstItem.SetFontSize(DG::Font::Small); short tabTotWidth = wd - 21; // scroll width short tabIdx = 1; short tabWid = 15; short tabBeg = 0; short tabEnd = tabBeg + tabWid; lstItem.SetTabFieldProperties(tabIdx, tabBeg, tabEnd, DG::ListBox::Center, DG::ListBox::EndTruncate, true, true); lstItem.SetHeaderItemText(tabIdx, "head 1"); // other header settings here // populate list box after // ... }But the list box is not showing. When I removed the header flag, the list will be created (of course) with no header.
EDIT
lstItem.SetPosition(xpos, ypos); lstItem.SetSize(itmWd, itmHt); lstItem.SetFontSize(DG::Font::Small); lstItem.Show();Shows (without header) when header flag is not set; otherwise, no list box is generated.
EDIT 2
~ReignBough~
ARCHICAD 27 INT (since AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-04-25 05:23 PM
2017-04-25
05:23 PM
the problem is in the initializer list.lstItem size is 0,0 because of DG::Rect() but you'd like to set header size to 25. That's why lstItem isn't created because its invalid state.
You should add initial size which height is more than 25:
SomeTabPage::SomeTabPage(...) : ... lstItem(GetReference(), DG::Rect(DG::Point (0, 0), DG::Point (100, 100)), DG::ListBox::VScroll, DG::ListBox::NoPartialItems, DG::ListBox::Header, 25) { // ... // modify size if initial one isn't appropriate lstItem.SetSize(itmWd, itmHt); //... }
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-05-15 04:11 AM
2017-05-15
04:11 AM
Thanks, Mihály Palenik. Most of the dialog items are fine when initialized with DG::Rect() (no parameter) . And set its size on the body. Now it is working. Thanks again.
~ReignBough~
