Selecting SEO operators
I'm trying to find and select all SEO operators. I'm fairly new to C++ and was wondering why this code doesn't work? The commented line crashes Archicad and I'm not sure why.
GS::GSErrCode err = NoError;
GS::Array<API_Guid> allElements;
ACAPI_Element_GetElemList(API_ZombieElemID, &allElements);
for (const API_Guid &guid : allElements) {
	GS::Array<GS::UniString> guidStrings;
	API_Guid **guid_Operators = nullptr;
	Int32 nLinks;
	err = ACAPI_Element_SolidLink_GetOperators(guid, &guid_Operators, &nLinks);
	BMhFree(reinterpret_cast<GSHandle> (guid_Operators));
	if (err != NoError)
		continue;
	GS::Guid nGuid = APIGuid2GSGuid (**guid_Operators); //crashes Archicad
	GS::UniString guidString = nGuid.ToUniString();
	guidStrings.Push(guidString);
	const USize count = guidStrings.GetSize();
	API_Neig** neigs = (API_Neig**)(BMAllocateHandle(count * sizeof(API_Neig), ALLOCATE_CLEAR, 0));
	for (UIndex i = 0; i < count; ++i) {
		(*neigs).guid = APIGuidFromString(guidStrings.ToCStr().Get());
	ACAPI_Element_Select(neigs, count, true);
	BMKillHandle(reinterpret_cast<GSHandle*> (&neigs));
If anyone could help that would be great.
Thanks
3 Replies 3
Can you explain here where do you put these C++ lines to be sure that everyone is able to understand ?
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
Ralph Wessel
It's because the data you want to inspect is destroyed in this line:
That instruction releases the memory used by that variable, so the data is no longer safe or meaningful, hence it crashes when you try to reference it in the following line:
Don't release the allocated memory until you're finished with it.
Ralph Wessel BArch
Central Innovation
Thanks for the replies. Currently I'm using this code in a ButtonClicked function in a modal dialog box. I've managed to fix it so that it functions as required.
void Dialog::ButtonClicked(const DG::ButtonClickEvent& ev) {
	if (ev.GetSource() == &button)
		Text.SetText(CalculateCount());
	else if (ev.GetSource() == &sButton) {
		if (sButton.GetText() == "Select")
			Text.SetText("Please use the drop down menu to choose\nwhat to select");
		else if (sButton.GetText() == sButton.GetItemText(1)) {
			Text.SetText("Close this dialog to finish selection");
			for (const API_Guid& guid : allElements) {
				API_Guid** guid_Operators = nullptr;
				Int32 nLinks = 0;
				if (err != NoError) {
					continue;
				API_Neig** neigs = (API_Neig * *)(BMAllocateHandle(nLinks * sizeof(API_Neig), ALLOCATE_CLEAR, 0));
				for (int i = 0; i < nLinks; i++) {
					(*neigs).guid = guid_Operators[0];
				ACAPI_Element_Select(neigs, nLinks, true);
		else if (sButton.GetText() == sButton.GetItemText(2)) {
				API_Guid** guid_Targets = nullptr;
				Int32 nLinks = 0;
				err = ACAPI_Element_SolidLink_GetTargets(guid, &guid_Targets, &nLinks);
					continue;
					(*neigs).guid = guid_Targets[0];
				BMhFree(reinterpret_cast<GSHandle> (guid_Targets));
Cheers.
