Archicad C++ API
Settings for proxy server
Geza Bohm
Hi!
I have noticed that the new DG-Browser item can use the system proxy settings, automatically.
That's great!
But what if I need manual proxy settings? Some software provide this feature, like web browsers, etc. Has ArchiCAD itself such a setting option? And can you set proxy for the Browser in DG?
Thanks in advance!
Best regards,
Geza
Tibor Lorantfy
Graphisoft Alumni
Hi All,
This blog post shows an example how to use the Browser Control (DG::Browser) in Add-Ons:
https://archicadapi.graphisoft.com/browser-control-and-javascript-connection
Currently manual proxy setting is not available
4 REPLIES 4
Eduardo Rolon
HI Geza,
What do you men by DG-Browser?
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
Geza Bohm
Hello Eduardo,
please check "Modules/DGLib/DGBrowser.hpp", it is a CEF based browser in ArchiCAD, you can use it in DG dialogs.
Regards,
Geza
Tibor Lorantfy
Graphisoft Alumni
Hi All,
Hi Tibor
What proxy setting does Archicad 25 use on Windows? Does it still go to the proxy settings from Internet Explorer?
Best regards,
Kevin Schumacher
