StaticTextMouseMoved is not called.
I was created simple UI with static text. And I want to do anything when cursor moves on the text, but the function StaticTextMouseMoved is not calling. Could you tell me if I do anything wrong?
class PluginAvailabilityManagementDialog : public DG::ModalDialog,
  public DG::PanelObserver,
  public DG::ButtonItemObserver,
  public DG::CompoundItemObserver,
  public DG::StaticTextObserver
public:
  PluginAvailabilityManagementDialog(GSResModule dialResModule);
  ~PluginAvailabilityManagementDialog();
private:
  virtual void PanelOpened(const DG::PanelOpenEvent& ev) override;
  virtual void ButtonClicked(const DG::ButtonClickEvent& ev) override;
  virtual void  StaticTextClicked(const DG::StaticTextClickEvent& ev) override;
  virtual void  StaticTextDoubleClicked(const DG::StaticTextDoubleClickEvent& ev) override;
  virtual void  StaticTextMouseMoved(const DG::StaticTextMouseMoveEvent& ev, bool* noDefaultCursor) override;
  static const short PLUGIN_AVAILABILITY_MANAGEMENT_DIALOG_RESID = 32530;
  enum
    LaterButtonID = 2,
    UpdateNowButtonID = 5,
    NewFeaturesButtonID = 6,
    textID = 3,
  DG::Button laterButton_;
  DG::Button updateNowButton_;
  DG::Button newFeaturesButton_;
  DG::LeftText leftText_;
PluginAvailabilityManagementDialog::PluginAvailabilityManagementDialog(GSResModule dialResModule) :
    DG::ModalDialog(dialResModule, PLUGIN_AVAILABILITY_MANAGEMENT_DIALOG_RESID, dialResModule),
    laterButton_(GetReference(), LaterButtonID),
    updateNowButton_(GetReference(), UpdateNowButtonID),
    newFeaturesButton_(GetReference(), NewFeaturesButtonID),
  leftText_(GetReference(), textID)
    AttachToAllItems(*this);
PluginAvailabilityManagementDialog::~PluginAvailabilityManagementDialog()
void PluginAvailabilityManagementDialog::PanelOpened(const DG::PanelOpenEvent& ev)
void PluginAvailabilityManagementDialog::ButtonClicked(const DG::ButtonClickEvent& ev)
void PluginAvailabilityManagementDialog::StaticTextClicked(const DG::StaticTextClickEvent& ev)
void PluginAvailabilityManagementDialog::StaticTextDoubleClicked(const DG::StaticTextDoubleClickEvent& ev)
  leftText_.SetTextColor(Gfx::Color::Green);
void PluginAvailabilityManagementDialog::StaticTextMouseMoved(const DG::StaticTextMouseMoveEvent& ev, bool* noDefaultCursor)
  DG::InformationAlert("Called","","OK");
/* ---------------------------------------------------------- Dialog */
'GDLG' 32530 Modal 40 40 445 561 "Dialog" {
/* [ 1] */ Icon  0 0 445 55 10018
/* [ 2] */ Button  141 412 160 44 LargePlain "Later"
/* [ 3] */ LeftText  110 115 223 19 LargeBold "Text"
/* [ 4] */ LeftText  121 150 201 28 LargePlain vCenter "Text center"
/* [ 5] */ Button  141 481 160 25 LargeUnderline noFrame BevelEdge "Update now"
/* [ 6] */ Button  141 170 160 25 LargeUnderline noFrame BevelEdge "features"
1 Solution
Viktor Kovacs
For performance reasons mouse move events are not called by default. Try to enable it on your control by calling the below function in your dialog's constructor:
myStaticText.EnableMouseMoveEvent ();
Go to post
3 Replies 3
Viktor Kovacs
Thanks a lot. It's work!!!
When I hover over the text, the StaticTextMouseMoved event is called, when I move the cursor from the text, no events are called. Are there any events for such a case?
For example:
When the cursor is over the text, the text turns red. When the cursor is not over the text, the text will be blue.
