dushyant
Decoding Strings in the GRC file
Hi
What do the alpha-numeric codes followed by ^ in the example below denote in a GRC file?
'STR#' ID_ADDON_MENU "Strings for the Menu" {
/* [  1] */		"Example AddOn Command... ^E3 ^ES ^EE ^EI ^ED ^ET ^10001"
^10001 - is for the icon
^E3, ^ES, ^EE... - what are these for?
Thanks
1 Solution
Viktor Kovacs
Those are defining which windows the menu command will be active over.
See the details here:
https://archicadapi.graphisoft.com/documentation/required-resources
Go to post
Viktor Kovacs
dushyant
Viktor wrote:
Those are defining which windows will be the menu command active over.
https://archicadapi.graphisoft.com/docu ... -resources
Thanks a lot Viktor!
