Hoa Tu
Suppressing Warning Message Dialog Box at Opening
Hi All,
I have an API which will open all the PLN files in the selected folder one at a time to process some tasks.
The API works fine until when it encounters a warning message dialog box such as duplicated library parts or missing file links etc.. in the opening of a file.
My question: Is there a way to suppress the warning messages so the API can loop through all the files without interruption by the warning messages.
Thanks,
Hoa
akomporday
Graphisoft Alumni
Graphisoft Alumni
Hey,
If you use commands, such as ACAPI_Command_Call, you can pass the parameter 'silentMode' with true value, so no dialogue will appear until the command is finished.
err = ACAPI_Command_Call (&mdid, 'GDCO', 1, parHdl, nullptr, /* silentMode = */ true);
For more info, see:
http://archicadapi.graphisoft.com/documentation/acapi_command_externalcall
