Archicad C++ API
_THROW1 error
ReignBough
I got the following errors.
1>...\api development kit 20.3012\support\modules\gsroot\GSNew.hpp(65): error C3646: '_THROW1': unknown override specifier
1>...\api development kit 20.3012\support\modules\gsroot\GSNew.hpp(65): warning C4595: 'operator new': non-member operator new or delete functions may not be declared inline
1>...\api development kit 20.3012\support\modules\gsroot\GSNew.hpp(65): note: to simplify migration, consider the temporary use of /Wv:18 flag with the version of the compiler with which you used to build without warnings
1>...\api development kit 20.3012\support\modules\gsroot\GSNew.hpp(65): error C2059: syntax error: '('
1>...\api development kit 20.3012\support\modules\gsroot\GSNew.hpp(66): error C2143: syntax error: missing ';' before '{'
1>...\api development kit 20.3012\support\modules\gsroot\GSNew.hpp(66): error C2447: '{': missing function header (old-style formal list?)
1>...\api development kit 20.3012\support\modules\gsroot\GSNew.hpp(74): error C2601: 'operator delete': local function definitions are illegal
1>...\api development kit 20.3012\support\modules\gsroot\GSNew.hpp(79): error C3646: '_THROW1': unknown override specifier
1>...\api development kit 20.3012\support\modules\gsroot\GSNew.hpp(79): error C2059: syntax error: '('
1>...\api development kit 20.3012\support\modules\gsroot\GSNew.hpp(79): error C2059: syntax error: ')'
1>...\api development kit 20.3012\support\modules\gsroot\GSNew.hpp(80): error C2143: syntax error: missing ';' before '{'
1>...\api development kit 20.3012\support\modules\gsroot\GSNew.hpp(80): error C2447: '{': missing function header (old-style formal list?)
1>...\api development kit 20.3012\support\modules\gsroot\GSNew.hpp(88): error C2601: 'operator delete[]': local function definitions are illegal
1>...\api development kit 20.3012\support\modules\gsroot\GSNew.hpp(94): error C2601: 'operator new': local function definitions are illegal
1>...\api development kit 20.3012\support\modules\gsroot\GSNew.hpp(100): fatal error C1903: unable to recover from previous error(s); stopping compilation
What might be causing it?
(Archicad 20 on VisualStudio 2017)
~ReignBough~
ARCHICAD 26 INT (from AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
Tibor Lorantfy
ARCHICAD 20 uses the Visual Studio 2010 toolset for building Add-On projects.
Unfortunately VS 2017 and VS 2019 both won't allow to install VS 2010 toolset, so you won't be able to build AC 20 Add-Ons with VS 2017 or VS 2019, you have to install VS 2010 itself.
1 REPLY 1
Tibor Lorantfy
