ā2025-01-02 10:08 PM - edited ā2025-01-05 10:56 AM
ā
I am reworking archicad 28 MEP addon for my needs. Is there any chance i can get some sample code for MEP input interface? In example all i found is mep functions but without input interface like place a point and draw rubber line. (there is interface_functions example with point input, line, polygon etc but lacks for typical MEP) For tracker i found tracker menager sample and found in documentation how to create new trakcer item which i think i am starting to understand.
I created some pretty basic input interface with rubber line snaping to angles etc but there i a lot of work to do to get it complete for usage (pet palette, trackers and much much more) and meabe there is a chance i could save time but just getting some example code for rework. In general concept of what is build in in archicad is good but it lacks here and there for my case of use. Same goes for MEP functions which are pretty limited and for me it doesnt fit and callback apparently doesnt help either becouse i cant change dimensions and bench angle to my neeeds becouse it is limited to referenceID's which are linked to build in category of dimensions. So whats even the point of this whole callback whole mep when u literally cant even change anything.
If there is any chance for this interface functions i can even contact you through our IT department which bought licences. This is must have for me š Just let me know. And in fact with MEP limitations i dont even think it is possible to input dimmensions like 17mm so do i cant add code for oval ducts becouse source code for creating circual or rectangular objects are hidden in binnary code...
ā2025-01-03 07:50 PM - edited ā2025-01-03 09:02 PM
If not meabe there atleast chance for some tips on tracker setup. So far i have this but tracker doesnt show up š any tips?
// Tracker
#include "ITrackerItem.hpp"
#include "Tracker.hpp"
#include "ACAPI/TrackerManager.hpp"
using namespace ACAPI::Tracking::v1;
// Przechowywanie wskaÅŗnika na tracker
static Tracking::Tracker *globalTracker = nullptr;
class MyCustomTrackerItem : public Tracking::ITrackerItem
private:
GS::UniString label;
GS::UniString value;
public:
MyCustomTrackerItem(const GS::UniString &label, const GS::UniString &value)
: label(label), value(value) {}
~MyCustomTrackerItem() override {}
void UpdateValue(const GS::UniString &newValue)
value = newValue;
GS::UniString GetToolTipText() const override
return label + ": " + value;
short GetHeight() const override
return 20; // WysokoÅÄ w pikselach
bool IsInInput() const override { return true; }
bool IsVisible() const override { return true; }
bool IsEnabled() const override { return true; }
bool AcceptEnabled() const override { return false; }
bool ReturnToRunningEnabled() const override { return false; }
// Puste funkcje, nieużywane w tym przykÅadzie
void SetParent(Tracking::Tracker &tracker) override {}
void ClearParent() override {}
void Draw(NewDisplay::NativeContext &context, const DG::Rect &itemRect, bool selected, short itemWidth[4]) override {}
void Synchronize() const override {}
DG::Item *ActivateEditMode(DG::Palette &palette, short itemWidth[4]) override { return nullptr; }
void DeactivateEditMode() override {}
short GetColumnWidth(short (&itemWidth)[4]) const override { return 0; }
DG::Rect GetActiveRectFromPoint(DG::Point point, short itemWidth[4], GS::UniString &toolTip) const override
return DG::Rect();
void FocusDefaultItem() override {}
DG::Icon GetExtraIcon(short &width, short &height) const override { return DG::Icon(); }
void ExtraIconClicked() override {}
static void InitCustomTracker()
// Uzyskanie menadżera Trackera
auto managerResult = ACAPI::Tracking::GetTrackerManager();
if (managerResult.IsErr())
DBPrintf("Nie udaÅo siÄ uzyskaÄ menadżera Trackera.\n");
return;
auto trackerManager = managerResult.Unwrap();
auto trackerRefResult = trackerManager.GetMainTracker();
if (trackerRefResult.IsErr())
DBPrintf("Nie udaÅo siÄ uzyskaÄ gÅównego Trackera.\n");
return;
// Rozpakowanie referencji i przypisanie wskaÅŗnika
globalTracker = &trackerRefResult.Unwrap().get();
// Dodanie niestandardowego elementu Trackera
auto customItem = new MyCustomTrackerItem("DÅugoÅÄ", "0 mm");
globalTracker->AddItem(customItem);
globalTracker->Show();
static void UpdateCustomTracker(const GS::UniString &distanceText)
if (globalTracker == nullptr)
DBPrintf("Globalny tracker jest niezainicjalizowany.\n");
return;
// Pobranie widocznego elementu
auto item = globalTracker->EnumerateVisibleItems();
if (item == nullptr)
DBPrintf("Nie znaleziono widocznych elementów trackera.\n");
return;
// Oczekiwanie, że item jest wskaźnikiem na Tracking::ITrackerItem
if (*item == nullptr)
return;
// Próbujemy rzutowaÄ na MyCustomTrackerItem
if (auto *customItem = dynamic_cast<MyCustomTrackerItem *>(*item))
customItem->UpdateValue(distanceText);
else
DBPrintf("Element trackera nie jest typu MyCustomTrackerItem.\n");
void CreateCustomTracker()
InitCustomTracker();
UpdateCustomTracker("100 mm");
static void RubberLineCallBack(const API_RubberLineInfo *info)
API_RubberLineType rubberLine;
// Wyzerowanie struktury linii pomocniczej
BNZeroMemory(&rubberLine, sizeof(API_RubberLineType));
// Przechodzimy przez wszystkie punkty w wektorze
if (theCoords.size() >= 2)
for (size_t i = 1; i < theCoords.size(); ++i)
rubberLine.c1.x = theCoords[i - 1].x;
rubberLine.c1.y = theCoords[i - 1].y;
rubberLine.c1.z = theCoords[i - 1].z;
rubberLine.c2.x = theCoords[i].x;
rubberLine.c2.y = theCoords[i].y;
rubberLine.c2.z = theCoords[i].z;
ACAPI_UserInput_DrawRubberLine(&rubberLine);
rubberLine.c1.x = theCoords[theCoords.size() - 1].x;
rubberLine.c1.y = theCoords[theCoords.size() - 1].y;
rubberLine.c1.z = theCoords[theCoords.size() - 1].z;
rubberLine.c2.x = info->actCoord.x;
rubberLine.c2.y = info->actCoord.y;
rubberLine.c2.z = info->actCoord.z;
// Rysowanie linii pomocniczej
// Obliczanie odlegÅoÅci i aktualizacja trackera
double distance = sqrt(pow(rubberLine.c2.x - rubberLine.c1.x, 2) +
pow(rubberLine.c2.y - rubberLine.c1.y, 2));
GS::UniString distanceText = GS::UniString::Printf("%.2f mm", distance);
UpdateCustomTracker(distanceText);
// Function to get input from user :
// Funkcja do dodawania punktu
void AddCoordPoint(API_Coord3D point)
theCoords.push_back(point); // Dodajemy punkt do wektora
// Funkcja do kasowania ostatniego punktu
void RemoveLastCoordPoint()
if (!theCoords.empty())
theCoords.pop_back(); // Usuwa ostatni punkt
else
printf("Brak punktów do usuniÄcia!\n");
// Funkcja do czyszczenia wektora
void ClearCoordPoints()
theCoords.clear(); // Usuwa wszystkie punkty z wektora
theCoords.shrink_to_fit(); // Zmniejsza pojemnoÅÄ wektora, jeÅli to możliwe
// Funkcja do dostÄpu i wyÅwietlania wszystkich punktów
void DisplayCoords()
for (size_t i = 0; i < theCoords.size(); i++)
printf("Punkt %zu: (%f, %f, %f)\n", i + 1, theCoords[i].x, theCoords[i].y, theCoords[i].z);
// Funkcja obliczajÄ
ca odlegÅoÅÄ miÄdzy dwoma ostatnimi punktami 3D i sprawdzajÄ
ca, czy sÄ
blisko siebie
bool AreLastTwoPointsClose(double tolerance = 0.001)
if (theCoords.size() < 2)
return false; // MuszÄ
byÄ co najmniej dwa punkty, aby to sprawdziÄ
// Pobierz ostatni i przedostatni punkt
const API_Coord3D &lastPoint = theCoords.back(); // Ostatni punkt
const API_Coord3D &secondLastPoint = theCoords[theCoords.size() - 2]; // Przedostatni punkt
// Obliczenie odlegÅoÅci euklidesowej
double dx = lastPoint.x - secondLastPoint.x;
double dy = lastPoint.y - secondLastPoint.y;
double dz = lastPoint.z - secondLastPoint.z;
double distance = sqrt(dx * dx + dy * dy + dz * dz);
// JeÅli odlegÅoÅÄ jest mniejsza niż tolerancja, to punkty sÄ
blisko siebie
return distance < tolerance;
