Archicad C++ API
Unable to change parameter "B"
CHCopyC ("B",chgParam.name);
			 chgParam.realValue = Value;
			 err = ACAPI_Goodies (APIAny_ChangeAParameterID, &chgParam, NULL);
I change parameter "B" value and after using function:
err = ACAPI_LibPart_GetParams (LibIndex, &aa, &bb, &addParNum, &getParams.params) ;
"B" value turns back to "default" as it was before. How could i fix this so calling "B" (with ACAPI_LibPart_GetParams) returns changed value ?
Other parameters works fine have just problem with "A" and "B" after using ACAPI_LibPart_GetParams.
5 REPLIES 5
ACAPI_ELEMENT_MASK_SET (mask, API_ObjectType, yRatio);
	memo.params = getParams.params;
Maybe there is an issue with mask? By using mask differently could i get changed "B" after using ACAPI_LibPart_GetParams ?
Now i ran parameter change function again after ACAPI_LibPart_GetParams, it seams that parameter have changed, but when creating object it creates object without changed "B" parameter although API shows "B" is changed value.
I'm surely missing something. Parameter update or something..
Soooo...
I didn't solve my issue, but!
By using elem.object.xRatio = valueX;
elem.object.yRatio = valueY;
I did find workaround to get desired A and B positions. No idea why i couldn't change A and B.
Ralph Wessel
Mentor
Rinovo wrote:
Soooo...
The axial geometry of library parts is a bit messy in the API. If we're setting trying to set the axial width (for example) we set both the 'B' parameter and the xRatio field, but it's the latter that matters. Also take note of the useXYFixSize field – when false, the width is calculated as xRatio multiplied by the default library part 'B' parameter value.
Ralph Wessel BArch
Active Thread Ltd
Thanks Ralph, for pointing out useXYFixSize.
Now i see why xRatio didn't multiply, i was already wondering why didn't it multiply.
My first though was to use xRatio multiplier to calculate desired 'B' width. Turned out i can just set xRatio as desired width value.
