Archicad C++ API
Uninitialized variable in Master script
jc4d
I'm modifying an existing label via gdl, the problem is when I check the script it throws a warning saying: Uninitialized variable in Master script.
I have no idea on how to fix it. Here is a screnshot of the highlited row that gives the warning:
Cheers.
jc4d
There was a mispelling on my side, now everything is up and running.
1 REPLY 1
jc4d
