ā2020-02-02
05:43 PM
ā2022-10-04
04:22 PM
Daniel Kassai
#include "APICommon.h"
#include "ResourceIDs.hpp"
#include "DG.h"
#include <windows.h>
// Window callback procedure
LRESULT CALLBACK WindowProc(HWND hWnd, UINT uMsg, WPARAM wParam, LPARAM lParam)
switch (uMsg)
case WM_DESTROY: PostQuitMessage(0); break;
default: return ::DefWindowProc(hWnd, uMsg, wParam, lParam);
return 0;
// creating a window with the Windows API
HWND CreateWindow(WNDCLASS wc, HWND hwndMainWindow)
// Create the window.
HWND hwnd = ::CreateWindowEx(0, wc.lpszClassName, L"", WS_OVERLAPPEDWINDOW, CW_USEDEFAULT, CW_USEDEFAULT, CW_USEDEFAULT, CW_USEDEFAULT, hwndMainWindow, NULL, wc.hInstance, NULL);
if (hwnd == NULL)
return 0;
::ShowWindow(hwnd, SW_MAXIMIZE);
return hwnd;
bool OpenBrowser()
HWND hwndMainWindow = ACAPI_GetMainWindow();
// disable the main window of Archicad
::EnableWindow(hwndMainWindow, FALSE);
// get instance of application
HINSTANCE hInstance = ACAPI_GetExtensionInstance();
// create window class
WNDCLASS wc = { };
wc.lpfnWndProc = WindowProc;
wc.hInstance = hInstance;
wc.lpszClassName = L"Browser Window Class";
// register window class
if (!::RegisterClass(&wc))
return false;
bool bResult = false;
DG::Browser* browser = nullptr;
// create a modal window
HWND hWndBrowser = CreateWindow(wc, hwndMainWindow);
if (hWndBrowser != nullptr)
RECT rect;
const BOOL bRect = GetWindowRect(hWndBrowser, &rect);
if (bRect)
const DG::Rect dgRect((short)rect.left, (short)rect.top, (short)rect.right, (short)rect.bottom);
// create browser in modal window
browser = new DG::Browser(dgRect);
browser->SetUpForNativeWindow(hWndBrowser, dgRect);
browser->LoadURL("https://google.com/");
// Main message loop:
MSG msg;
while (::GetMessage(&msg, NULL, 0, 0))
::TranslateMessage(&msg);
::DispatchMessage(&msg);
bResult = true;
// unregister window class, freeing the memory
::UnregisterClass(wc.lpszClassName, hInstance);
// enable the main window of Archicad
::EnableWindow(hwndMainWindow, TRUE);
// TODO: crashes if deleted
//delete browser;
return bResult;
Solved! Go to Solution.
ā2020-02-04 02:40 PM
ā2020-02-02 06:59 PM
Martin wrote:Would there be a problem creating the window using the ARCHICAD API rather than the Windows API? I believe your efforts are much more likely to be successful if you use one API for your UI workflow.
I'd like to use the DG::Browser embedded in a modal window created by the Windows API.
ā2020-02-04 01:14 AM
ā2020-02-04 11:21 AM
ā2020-02-04 01:40 PM
#include "DialogBrowser.h"
#include "DG.h"
#include "DGModule.hpp"
DG::Browser* browser;
// browser dialog handler (callback)
static short DGCALLBACK DialogBrowserHandler(
short message,
short dialogID,
short item,
DGUserData /*userData*/,
DGMessageData /*msgData*/)
short result = 0;
switch (message)
case DG_MSG_INIT:
HWND hWndMain = ACAPI_GetMainWindow();
if (hWndMain)
HWND hWndDialog = GetWindow(hWndMain, GW_HWNDPREV);
if (hWndDialog)
RECT rect;
if (GetWindowRect(hWndDialog, &rect))
break;
case DG_MSG_CLICK:
switch (item)
case DG_OK:
case DG_CANCEL:
result = item;
break;
break;
case DG_MSG_CLOSE:
result = item;
break;
return result;
bool OpenBrowser()
// Get the browser dialog from our resource file
const short result = DGModalDialog(ACAPI_GetOwnResModule(), ID_DIALOG_BROWSER, ACAPI_GetOwnResModule(), DialogBrowserHandler, 0);
return result;
And the .grc:ā2020-02-04 02:05 PM
Browser (const Panel& panel, short item);
ā2020-02-04 02:18 PM
