Archicad C++ API
What action can trigger API_IAttributeEventHandler
WalterWhite
I find that the APIdefs_Callback.h file has API_IAttributeEventHandler, and I want to know what action can be triggered.I tried to change the material of the element but it didn't trigger.
4 REPLIES 4
I think it's triggered when you change the attribute definitions themselves in the Attribute Manager, Attribute Palette or specific Attribute Dialog.
If you want to catch a material change in an element, then you'll need APINotifyElement_Change.
Checkout the Notification_Manager example.
Also here's a related code example: https://graphisoft.github.io/archicad-api-devkit/group___element.html#gad0a9295057964fa5e4a3cfd105bf...
Automating Archicad with Add-Ons, GDL-Objects & Python Archi-XT.com
Ok,I'll go back and try. Thank you very much.
Viktor Kovacs
API_IAttributeEventHandler is called in case of an attribute created, modified, or deleted.
You need to create a class inherited from API_IAttributeEventHandler like this:
class AttributeEventHandler : public API_IAttributeEventHandler
public:
    virtual void OnCreated (const GS::HashSet<API_Guid>&) const override
        // do something
    virtual void OnModified (const GS::HashSet<API_Guid>&) const override
        // do something
    virtual void OnDeleted (const GS::HashSet<API_Guid>&) const override
        // do something
And you need to register the event handler like this in the Initialize function:
API_Guid eventHandlerId;
ACAPI_Notification_RegisterEventHandler (GS::NewOwned<AttributeEventHandler> (), eventHandlerId);
Ok, I'll have a try
