2025-11-19 02:45 PM
I’m trying to understand the purpose of the two optional Archicad API licenses:
Developer License – 500 €/year
Developer Support Service – 500 €/year
It’s not clear to me what real, practical benefits these provide compared to not purchasing any of them.
What exactly does the Developer License unlock that I wouldn’t have otherwise?
And what does the Developer Support Service actually give me in day-to-day development?
Also, what do I actually need to develop Archicad add-ins? Is the public API SDK enough, or is the Developer License required?
Any insights or experience would be appreciated.
Solved! Go to Solution.
2025-11-26 08:30 AM - edited 2025-11-26 08:32 AM
@Palawat thanks for pointing us to this! Not sure where I got the wrong information from. Probably misinterpreted something 😅
I don't experience the restriction with 2 versions of Archicad.
I have AC INT 23 - 29 installed on my PC and can use them all at the same time.
The license just doesn't work for other language versions in my case. But most of the time it's enough for me to run the other language versions in DEMO mode.
Best regards,
Bernd
2025-11-19 03:19 PM
Hi!
The Developer License is a cheaper Archicad license that is fully functional but you are not allowed to use it for producing drawings in your function as a draftsperson, architect etc. So if you have already an Archicad license from your job, there's no benefit in the developer license. It's mainly for people like me who's main profession is development.
The Developer Support Service is no longer available unfortunately.
You don't need any of the two points to develop Add-Ons. Public available SDK is enough. You still need to sign up in the Developer Registration to be able to create your Developer ID & Add-On IDs so you can distribute your Add-Ons. But I think this is free of charge.
Best regards,
Bernd
2025-11-21 09:44 AM
Yes, it is free.
The developer licenses help those developers who don't have access to Archicad otherwise.
Best, Akos
2025-11-24 03:31 PM
As I remember, it's not that ;
Or maybe it's changed and I didn't know about that. It'd be nice if someone from Graphisoft can confirm this.
And also, with developer license, you can only have 2 versions of Archicad installed on one maching at the same time.
Best regards,
Bernd
2025-11-27 04:44 AM
I was inform by email right when I first purchased dev. license. The license manager tool was quite wonky back then and I was afraid it would mess things up so I haven't tried installing more than 2 versions since then.
Thank you very much for sharing. It would make my life a lot easier supporting people still using old versions. 🙂
