Archicad C++ API
When I link lib to use ORACLE database - archicad say's "addon is outdated"
I need to use ORACLE database with ARCHICAD.
And when I link my add-on with lib from SDK Oracle Instant Client, ARCHICAD not recognizes my apx file as addon and writes that it is outdated.
Please help me understand what the reason is?
Ralph Wessel
Mentor
The message that an add-on is "outdated" is misleading – it's a catch-all error message for "something went wrong when an attempt was made to load the add-on". I suspect that the Oracle library also depends on other libraries and Archicad can't locate them at the point it attempts to load your add-on. It suggest analysing your add-on library dependencies - or reads the console output while the add-on is loading (it might state the missing dependency).
Ralph Wessel BArch
Active Thread Ltd
Ralph Wessel
Mentor
Ralph Wessel BArch
Active Thread Ltd
Thank you! I've just figured it out
