Streamline your workflows and master BIM coordination! Program starts April 28.!
Archicad C++ API
Why can't Add-On be used when I use curl?
luna
I am developing with AC24 and VS2017.
I want to use curl to access the Http interface and use JsonCpp to parse the data, but every time #include <curl/curl.h>, the Add-On doesn't work.
When I remove the #include <curl/curl.h> code, the plugin works fine.
Is this a version problem or some other reason, please give me some tips.
luna
The reason I found some details was the Get and Post functions, and when I added these two methods to the file, AddOn didn't work.
CURLcode HttpUtils::PostUrl(const string &url, string& response, const string&token, const string&postParams) {
	CURL*m_curl = curl_easy_init();
	CURL* m_curl = curl_multi_init();
	if (m_curl) {
		struct curl_slist* head_list = NULL;
		head_list = curl_slist_append(head_list, "Content-Type:application/json; charset=UTF-8");
		if (!token.empty()) {
			string tokenstr = "token:" + token;
			head_list = curl_slist_append(head_list, tokenstr.c_str());
		//tenant_id = "tenant-id" + const_;
		head_list = curl_slist_append(head_list, tenant_id.c_str());
		head_list = curl_slist_append(head_list, "Changhong-type:ARCHICAD");
		head_list = curl_slist_append(head_list, std::string("Authorization:Bearer " + token).c_str());
		curl_easy_setopt(m_curl, CURLOPT_HTTPHEADER, head_list);
		curl_easy_setopt(m_curl, CURLOPT_HEADER, 0);
		curl_easy_setopt(m_curl, CURLOPT_POST, 1);
		curl_easy_setopt(m_curl, CURLOPT_URL, url.c_str());
		if (!postParams.empty()) {
			curl_easy_setopt(m_curl, CURLOPT_POSTFIELDS, postParams.c_str());
		curl_easy_setopt(m_curl, CURLOPT_WRITEFUNCTION, req_reply);
		curl_easy_setopt(m_curl, CURLOPT_WRITEDATA, (void *)&response);
		curl_easy_setopt(m_curl, CURLOPT_NOSIGNAL, 1);
		curl_easy_setopt(m_curl, CURLOPT_CONNECTTIMEOUT, 20);
		curl_easy_setopt(m_curl, CURLOPT_TIMEOUT, 20);
		m_rescode = curl_easy_perform(m_curl);
	curl_easy_cleanup(m_curl);
	return m_rescode;
CURLcode HttpUtils::GetUrl(const string &url, string& response, const string&token) {
	if (m_curl) {
		head_list = curl_slist_append(head_list, "Content-Type:application/json;charset=UTF-8");
		//head_list = curl_slist_append(head_list, "token:"+);
		curl_easy_setopt(m_curl, CURLOPT_URL, url.c_str()); // url
		curl_easy_setopt(m_curl, CURLOPT_SSL_VERIFYPEER, false); // if want to use https
		curl_easy_setopt(m_curl, CURLOPT_SSL_VERIFYHOST, false); // set peer and host verify false
		curl_easy_setopt(m_curl, CURLOPT_VERBOSE, 0);
		curl_easy_setopt(m_curl, CURLOPT_READFUNCTION, NULL);
		curl_easy_setopt(m_curl, CURLOPT_CONNECTTIMEOUT, 3); // set transport and time out time
		curl_easy_setopt(m_curl, CURLOPT_TIMEOUT, 3);
		curl_easy_setopt(m_curl, CURLOPT_CONNECTTIMEOUT, 6);
		curl_easy_setopt(m_curl, CURLOPT_TIMEOUT, 6);
		// open post request
	return m_rescode;
luna
More specifically, the problem is with the curl_easy_  method.
ManelCG
The issue is most likely that curl is being linked dynamically. We also had this problem.
The most likely solution is to try to force Curl to be linked statically. That is, if on Windows, force it to compile as .lib and then link the .lib on it.
Generally, AC will give that error whenever it cannot find a dll, which will be almost every time when you link something dynamically.
I also recommend to give libcpr a try. It is a very, very easy to use and to include curl wrapper.
Good luck!
