Work with API
Hi all
I am brand new on this area (ArchiCad), but maybe someone can help me.
I need to take a elements and components and all other things from ArchiCad to another (calculation) software.
Is ArchiCad able to export this into some text (or XML) file?
Other way, can I use some DLL or some other library to "comunicate" with ArchiCad, and take all data into my software?
Thank you
Zdravko
The odbc driver is probably the easiest way to access this information for a programmer, however I dont think there is a driver for version 10 yet.
You might want to look on the Calculation forum as exporting data like you want can be done manually from inside archiCAD by a draftsperson.
