Archicad C++ API
Work with API
Hi all
I am brand new on this area (ArchiCad), but maybe someone can help me.
I need to take a elements and components and all other things from ArchiCad to another (calculation) software.
Is ArchiCad able to export this into some text (or XML) file?
Other way, can I use some DLL or some other library to "comunicate" with ArchiCad, and take all data into my software?
Thank you
Zdravko
1 REPLY 1
The odbc driver is probably the easiest way to access this information for a programmer, however I dont think there is a driver for version 10 yet.
You might want to look on the Calculation forum as exporting data like you want can be done manually from inside archiCAD by a draftsperson.
